Tip & How-To about Computers & Internet
How to Break Windows Administrator Password from DOS Command Prompt?
A windows administrator account is a user account that gives full access to the machine. It is by far the number one target for someone trying to gain illegal access to your network and resource. So Administrators should change administrator password frequently to avoid unauthorized access to the domain or desktop machine.
Then something bad happens. Password can be easily forgot or lost. If you forgot windows administrator password, how could you break windows administrator password and gain access to your admin account?
Here is how to break windows administrator password from DOS command prompt
  1. Login as administrator or user account that has administrator privileges.
  2. Click Start -> Run
  3. Type CMD
  4. Then the DOS shell screen will appear like below, Type "net user username password/domain" into the command prompt.
  5. Replace username with the user account you login and the password with the new password you want to assign to that account. /domain is optional. If you are in a domain, specify the domain otherwise leave it.
  6. Once you click Enter, your password will be changed, like the example, the administrator will change the password of the user Michelle to 123456.
NOTE: If you do not have administrator rights on the machine, you will get the error message stating "System error 5 has occurred. Access is denied."
If you receive this error message that means you couldn't break windows administrator password from DOS command prompt. At this time, SmartKey Windows Password Recovery comes in hands.
SmartKey Windows Password Recovery is a powerful password hacking which can help to break Windows administrator and domain password by burning a bootable Windows Password Reset CD/DVD or USB flash drive. With this bootable password reset cd, breaking windows admin password is a child's job.
Here is how to break windows administrator password with Windows Password Recovery
Step 1: Download and install SmartKey Windows Password Recovery software.
Step 2: Burn Windows Password Recovery software to CD/DVD or USB flash drive.
Step 3: Breaking the lost or forgotten windows administrator password.
Only need 3 simple steps. Your windows administrator password has been broken.
Contact:
Official Website: http://recoverlostpassword.com/products/windowspasswordrecoery.html
Email: support@recoverlostpassword.com
Related Article:
How to Break Word password?
Article Source:
http://recoverlostpassword.com/article/break-windows-administrator-password-from-dos.html
Computers & Internet Logo
i CAN NOT GET ON LINE ,MY id WONT WORK NOT MY PASS .
With the information you have provided it is hard to say what the issue might be. Could you please be more specific in what is happening? Is it password related to the PC? Is it sluggish performance? Is it missing program links? is it internet access?
Mar 25, 2014 | E-Machines eMachines Desktop PC
change password
Change password for what ?
Use dos comand
The administrator account on a Windows machine is the main, root user name that gives full access to the machine.
Administrators should change this password frequently to avoid unauthorized access to the domain or desktop machine.
This can be done in the Windows Control Panel, or use the "net user" command in the Windows DOS prompt.
Log in to the machine using the administrator username and password.
You can also use an account that has administrator privileges on the domain or desktop computer.
Click the Windows "Start" button and select "Run" or "Start Search" (depending on your version of Windows).
In the text box displayed, enter "cmd" and press the "OK" button.
This opens the command prompt window.
Type "net user administrator <new password>" into the command prompt.
Replace "<new password>" with the password you want to set.
Enter the password again for confirmation.
Once you enter it again, the administrator password has been changed.
Test the new password by rebooting the machine and logging in with the new administrator password.
Dec 05, 2013 | Computers & Internet
assign ip address
Which operating system and type of router ?
Use dos comand
Nov 29, 2013 | Computers & Internet
I was given a compaq computer running Windows XP. It boots up to a previous user and is looking for that user's password. How can I reset password or access administrator account?
I would suggest you to try the following :
Boot the computer in safe mode.
Press F8 while booting the system, It will give you Windows Advance boot option, Select Safe mode and press Enter. You will see two accounts, Administrator and the Previous User's . Select the Administrator. If it allows you to log in, go to control Panel, User Accounts and delete the previous user's account and create a New user with your name. Reboot the computer in normal mode.
Hope this works. Please let me know if you need further Assistance. Your comments and ratings are highly appreciated.
Thank you for choosing Fixya
Oct 14, 2009 | Compaq Presario S6000CL (DT072A) PC...
458 people viewed this tip
David Payne
David Payne
