Tip & How-To about Computers & Internet
Lost Acer Windows 7 Logon Password?
The netbook is redefined with the arrival of the Acer Aspire computer and many people like it. Most of them intall Windows 7 Operation System. As you know, a logon password should be created to protect your Windows 7 user account. Sometimes, you lost Windows 7 logon password, how to reset it on your Aspire laptop? E.g. Acer Aspire One
Notes:
1. If you don't have created a password on Acer netbook, you may be insterested in this tutorial: " How to Create A Windows 7 Logon Password?"
2. If you forgot Windows 7 User password, you have 2 methods to retrieve it. One is below steps, another is this guide: " Reset Windows 7 Password With a Password Reset disk that was created before you forgot Password "
About Acer Aspire Aspire is a series of personal computers by Acer Inc. aimed at the casual household user or for small business use. The Aspire series covers both desktop computers and laptops. Acer developed the series in order to cover from essentials to high performances.
How to Reset Windows 7 Password on Acer Aspire? Just follow below steps to recover your Acer PC password, it will only take your few minutes.
1. Login another computer that you have access, download Windows Password Recovery Tool Professional, install and run it.
2. Burn a Aspire laptop password reset disk, you can use CD/DVD or USB Flash Drive. I recommend USB if the locked Aspire laptop supports it.
3. Connect the password reset disk with the locked Acer computer, Press "Del" while the computer just start, then go to bios setting to boot computer from the USB Flash Drive, reboot the computer to load the program.
4. Select the user account which you lost itslogon password, click "reset" button to begin resetting password.
5. A message box will pop up, just click "Yes", then the user's password will be hacked.
6. Disconnect the password reset disk, and reboot Acer PC. You will login Windows 7 without password.
Screenshots on resetting Aspire Computer Password
Finally Acer Windows 7 Password Recovery is not a difficult thing, you don't need to become a expert. Above experiment was carried out under Windows 7, but this tool also supports Windows XP, Vista, 2008, 2003, 2000.
Tips: 1. You can create a Aspire Password Reset disk before your lost Windows 7 Account password.
2. Keep in mind that this software can be only used on your own computer, never try to use it to hack other person's login password without permission. Otherwise, you will be caught by police.
Computers & Internet Logo
My daughter lost her password for her netbook how do I rest it
Hello first of all what operating system is she using if windows xp then boot the machine in safe mode, chances are it came out the factory with no password on the hidden admin, after you boot into safe mode you will notice a new account you haven't not seen before call administrator. choose the admin and once in the account simply go to user accounts and remove her password. if you are running vista or windows 7 then this will not work for you the next option would require software I recommend hirens boot cd 10.6 here is the link bootcd download and extract the file, you need a archive program like winzip or winrar. the zip file wil contain an iso image of the disk that you will need to mount and burn to a disk would use damon tools which is also free. once you have created your boot disk you can now boot your daughters computer from the boot cd, once booted into hirens several tools with appear simply navigate to password tools and follow the step by step wizard that will remove the password in seconds.
hpe this helps please feel free to reply for more detailed support.
May 29, 2011 | Acer Aspire One Netbook 8.9" Notebook
how do i change my acer login password
Lost Acer Windows 7 Logon Password? ' How to reset Acer Aspire One password if you don't know it?
  • The netbook is redefined with the arrival of the Acer Aspire computer and many people like it. Sometimes, you lost Windows 7 logon password, how to reset it on your Aspire laptop?
May 14, 2011 | HP Mini 1000 Netbook
My daughter forgot her password on emachine E725 and can not boot. How can we reboot the computer? Thank you.
Assuming that you mean the Windows log in password, try using blank (none) as password (otherwise at the log on screen hit "enter"). If this doesn't work log on at the administrator's account. To do this if you can see the administrator's icon click on it and use blank (none) for password again. If you can't see the administrator's icon, hit ctrl+atl+del TWICE and type as user "administrator", blank (none) for password and hit enter. After you log on as administrator change your user's account as you wish and you are ready to go.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Apr 02, 2011 | Acer eMachines 520-2890 Notebook
my son changed his password on his netbook. now he doesn't remember it. he cannot log in at all. he can do absolutely nothing with it. how can we fix this?
at Windows XP's Welcome Screen, simply press Ctrl-Alt-Del keys sequence together twice, and you will be shown a Log On to Windows menu where you can specify the User Name and Password. In the User Name text box, key in "Administrator" (without quotes) and leave the Password field blank. Then press Enter or click on OK. If there it is not a password protected Administrator account, or blank password is set, then you will be able to access the Windows with full administrative privileges as Administrator.
Then simply click start > control panel > User accounts then select your sons account and click edit then click remove password. once done simply log off and then log in to your sons account and no password will be asked for. If your son is the root administrator then you will need to get software to reset the password for you
Mar 23, 2011 | Computers & Internet
424 people viewed this tip
David Payne
David Payne
