Tip & How-To about NRS Fleck 5600 - 64,000 Grain Timer Water Softener
Water Softener maintenance tips: By-Pass Valves
There are many types of factory By-Pass valves and 3-Valve By-Passes systems used on residential water treatment equipment. Over the course of years if these valves have not been used they become very hard to turn and may require the use of a wrench to turn them. This can create a big problem if an emergency occurs with the water treatment system and the water needs to be turned off. Using a wrench on any bypass valve has the potential to break it and then it won't work or worse, you have a flood on your hands as water comes gushing out of the valve!
What is the solution? The easiest solution is to turn the by-pass valve on and off several time every time you add salt to the system. By doing this it loosens any debris, keeps the o-rings lubricated an the valve moving freely.
Many systems incorporate by-pass valves with handles that simply turn 90 degrees for on and off. While manufacturers like GE, Sears, Ecowater, Culligan, Northstar, Hague among others incorporate a simple push pull valve to by-pass the system. Other companies by-pass systems may be "hardplumbed" with a 3-Valve by-pass that incorporates an inlet, outlet and center (By-Pass) valve to divert hard water past the treatment system when needed.
Which ever type is used with your system it is best to turn or push these valves ON and OFF several times every time salt is added (generally quarterly) to assure proper operation of the by-pass system to prevent any problems when it is crucial for them to work properly.
Practice these tips and your water treatment system will give you many years of quality water with fewer service issues.
Good Luck and Good Water,
RJ
NRS Fleck 5600 - 64,000 Grain Timer Water Softener Logo
softener is making slight grinding type noise working ok
Either it's getting old and you should start saving for a new one or you need to find a local water treatment dealer who is a Certified Water Specialist (find at WQA.org) to get yours rebuilt. If it's 10 years or older it will likely be cheaper in the long run to replace it. The softener with the fewest moving parts and the longest frequency to first repair also has the longest factory warranty on the electronics and valve: Autotrol. Built by Pentair Residential Filtration.
Sep 06, 2014 | Water Dispensing & Filtration
my water supply pump to house works but does not pump water from tank to house
What type of pump is it? Is it a shallow well pump or submersible
pump? Is the pump connected to a pressure tank? How have you confirmed that the pump is working properly? Is there a drain valve, and is there water pressure from the drain valve when it is opened? If the pressure tank is of the pre-charged type, is it working properly? Is there water coming out of the air valve? Are there any shut-off valves in the system which may have been turned off, preventing water flow?
Apr 17, 2014 | Saniflo 021 Saniswift Residential Water...
what preventive maintenance should be carried out on salt water sofeteners
in as far was the water softener you need to do your salt tank, about every two years let the salt get low. when its hit a low point with proper safety gear face mask and eye cover and gloves remove the old salt and wash out the tank. then install new salt dispose of the old salt. I bury mine where I dont want grass th grow.
The tank itself should be cleaned and re charged about every 3 years fo a family of 4, If you have a double tank system you can go 4 years.
In as far as what can you do for a fauect and valves just keep the outside clean, like a watter heater spray the pipes with WD 40 inside the pipes under the sink WD 40 them on top just keep them clean with soap and water. If you see a spot that is starting to rot. Take a tooth brush and (an OLD ONE) brush the area. now take so food oil and wipe it down let it sit for a hour then with a dry cloth buff the area. repeat when needed.
I hope that I covered everything you were looking for
Be safe and have fun
Tom
Could you take a second to rate our work it gives up feed back how we are going and what we might need to do better
Sep 11, 2011 | Plumbing
water runs continuosly...I have well water and when this occurs, the drinking water tap just trickles...and also the water filter life is greatly reduced
If it's like my well water was there was sand in the water which would lodge in the water inlet valve where the water supply connects to the fridge on the back. It prevents the valve from closing completely. Sometimes it would clear it's self if you keep cutting it on and off till it stops. I also had the same problem with the cold water in the washer. Replacing the valve didn't help because the sand kept coming. Some type of filter is needed in the water line before the fridge is needed.
Jan 16, 2010 | GE Monogram ZDI15C Automatic Icemaker
Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Mar 29, 2009 | Bosch KGU66920 Side by Side Refrigerator
1,058 people viewed this tip
Top NRS Home Experts
Donni Steen
john h
Bill Boyd
Are you a NRS Home Expert? Answer questions, earn points and help others
