Tip & How-To about Heating & Cooling
GM - Cars and Trucks with duel zone climate control
Most GM vehicles with separate driver side and passenger side heat and air conditioning can have problems with having heat on one side and cold on the other . The dealer has a computer that can calibrate these systems when the mess up to determine if it has a bad accuator or it's just lost memory. I worked for GM and read thru a test manuel and found that you don't have to have the computer to reset or test this system. If you disconnect the battery for 10 minutes then hook the battery back up , start the vehicle turn the fan switch to medium , do not touch any other part of the system , the climate control will go into a self calibration mode, wait untill it goes thru this self test mode, aproximately 2 to 3 minutes .During this mode you will feel and hear the accuators moving thru their ranges. After they stop changing postions now set your desired temperature for both sides if their is no hard faults (failed parts) the system will resume normal operation . If one or the other still does not blow the correct temperature replace that sides temp accuator repeat the self test mode and you should be fixed.This is a quick and easy way to test your own climate system with out paying the dealer their 100 dollar computer diagnostic fee.
Heating & Cooling Logo
Toyota D4D 2007 Verso Side Blows Cold Air driver side warm in passenger side
the best first thing to do is check for a rodent nest in your system, look into the hvac air intake which should be under the cowl cover on the passenger side. if there is debris in there you have a rodent nest which needs cleared out. if your vehicle has a cabin air filter this is where the intake for the hvac is.
Feb 02, 2015 | Toyota Cars & Trucks
why does my peugeot 307 sw 1.6 dt. air conditioner blow cold air out of passenger side and hot air out of driver side?
Blend door on passenger side may not be functioning properly either because of linkage or sensor not getting the proper message from the control.
Aug 01, 2014 | Air Conditioning and Heat for Peugeot 405
AC unit blows cold on passenger side and warm on driver side.
There are separate blend doors for the passenger and driver's side. The blend doors divert, not block air, so it is unlikely that the blend doors are the problem. You need to check the operation of the re-circ door.
There may be some more duct work that attaches to the heat/air conditioning housing under the dash, that supplies air and or heat to both the driver side and passenger side of the car, the duct work on the driver side may have come disconnected.Check this also.
Hope this helps
Thanks
Smith.
Sep 11, 2009 | 2008 BMW 528i Sedan
354 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
