Tip & How-To about Refrigerators
Ice maker not working
This problem where the icemaker is not working properly is usually broken into sections on diagnoseing the issue of why your not getting ice out of the icemaker. One of the first things that you should check is if the icemaker is getting water to the ice tray. If you are not getting water to the ice tray then the first thing you should check would be your water filter. If your water filter is clogged or dirty you will not get any water going to the icemaker. Following checking the filter and if you still had no water going to the icemaker you would then go around the back of the machine and test the water valve. By using a multimeter you can test the two connectors that plug onto the solenoids to assure that you do have power going to the water valve. Also in some cases you may be able to disconnect the line and clean the small screens on the inside of the valve but most of the time if there is any issue with the valve it is by far easier to just replace the water valve itself. If you do have water going to the Ice maker yet your icemaker is still not working. You can also try defrosting the ice maker by disconnecting the three screws holding the ice maker in place and removeing the entire icemaker and running it under hot water. Sometimes this does help to defrost parts that are froozen in the unit. If after you reinstall the ice maker and you do have water going to the ice maker yet your unit still does not produce ice, and you can feel ice on the inside the tray and you have tried defrosting the ice maker. It is always easier and cheaper to replace the ice maker as a whole rather then buying parts for the ice maker which would cost you about Four times as much as buying a new icemaker
Refrigerators Logo
No water to the ice maker .I took out the cover of ice maker turn by hand the wheel after one cycle .I heard the sound and water filling up ice maker but when it become ice for long time .the ic
Hi friend, thanks for your post!
I understand that your icemaker on your Frigidaire refrigerator is not getting water to the icemaker. It sounds like you could have an issue within the valve or solenoid. I would recommend having a professional come out to properly diagnose your appliance and repair it. -Matt
Sep 17, 2014 | Frigidaire Refrigerators
ice maker will not make ice. everything in installed properly. unit is 7 years old. red light flashes twice, then pauses and flashes twice again.
in the door ice storage. this is complicated. might check at the bottom of ref. there is a removable toe panel and on the back of the toe panel usually there is wiring diagram & mini manual to help diagnose icemaker problems.
Jan 03, 2010 | KitchenAid KSSS36QK Side by Side...
Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Dec 24, 2007 | Frigidaire FRS23KF7AB Side by Side...
874 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
