Tip & How-To about Computers & Internet
Stay Away from Windows Password Recovery Issues on Sony PC
The Sony computer uses a Microsoft operating system to give users the ability to create and edit digital files through the graphical user interface. In our daily life, we are used to create a Windows password for Sony Vaio Passwords which are highly useful at protecting your personal information until you forget the combination, leaving you locked out of your laptop.
If you have a Sony Vaio, how would you deal with the forgotten or lost Sony Windows password for your laptop? This topic is going to discuss the easiest methods to stay away from Windows password forgotten issues on Sony Vaio for Windows 7<Vista and XP according their special features.
1. Reset Windows 7 Password with Fingerprint Logon on SonyThis method now can only be used for Windows 7, which is relied on fingerprint biometric device through Windows Biometric Framework. It makes easy for administrators and users to configure and control on a local or domain computer which will prevent from password lost. So as long as you have made a fingerprint for the Windows 7 Sony Vaio, you will never worry about the forgotten Windows 7 password issue any more.
2. Retrieve Vista Password with Password Hint on SonyIt is well-known with the password hint function for Windows Vista users. When creating a password to log on to Windows, you can create a hint which can do a great favor if you forgot the Windows Vista password. The password hint will not appear until you input a wrong Vista password.
3. Reset XP Password on Sony Vaio by Default Administrator accountWe can use default administrator account for Sony Vaio Windows password recovery. There is a built-in Administrator user account in Windows XP that is auto generated when we install the PC and with password blank. If we didn't change this Administrator's password, then boot system from Safe mode and login in with the accounts to reset lost Sony Windows password.
These 3 methods above for reset windows password on Sony are easy to operate to solve Windows password recovery trouble if necessary. By the way, if you own a bootable CD/DVD or USB flash drive, it is also portable to create a Windows password reset disk with a password recovery toolkit. As is known, Windows Password Unlocker is highly appreciated for password recovery on Windows 7/XP/Vista/2000 and Windows Server 2003/2008.
Computers & Internet Logo
how to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
windows vista
Windows Vista is the new operative system distributed from Microsoft, following the previous release of Windows XP.
An operative system is the interface between the user (you ) and the computer, that allows you to manage computer hardware resources and peripheral, and manage processes (software) running on your computer.
From the user point of view The operative syste is the environment where you run applications, manage connected devices, storing files and starting and stopping programs.
Vista is the latest OS released from Microsoft. It has a powerful interface, but it can be slow running on old computers. On vista you can also have some compatibility problem when you try to install old devices built for XP, such as printers, scanners etc.
See here
Windows Vista home page
Sep 11, 2008 | Microsoft Windows Vista Ultimate Edition
What is the difference between unix and linux
UNIX is a operating system which has only command user interface, and if the unix is installed in the system you cant install any other operating system after that ... one separate system must be allocated for the unix ...
LINUX is the graphical user interface and it supports multiple operating system ..
UNIX and LINUX are almost same, almost all commands which supports in UNIX supports in LINUX too .. with some extended features just like GUI(GRAPHICAL USER INTERFACE),SECURITY,MULTI USER,MULTI TASKING,etc
COMMAND USER INTERFACE - the input is made to the computer by using commands and the output is obtained by command or by printer ...
GRAPHICAL USER INTERFACE- the input is provided to the computer through the other input devices like mouse,joystick etc
the input is provided either by command or by the just clicking the mouse on the particular icon ...
example for graphical user interface is windows,Macintosh etc ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
Aug 19, 2008 | Microsoft Windows Server Standard 2003 for...
225 people viewed this tip
David Payne
David Payne
