Tip & How-To about Computers & Internet
Steps to create a bootable Vista or Windows 7 USB flash drive for the purpose of installing
Steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS
Microsoft Provides a tool to do this for you - Windows 7 USB/DVD Download Tool which is available for download here. If you need instructions on how to use the tool, see the Microsoft Store Help on the ISO-Tool (http://store.microsoft.com/Help/ISO-Tool).
or
Please follow the steps below
Required:
  • USB Flash Drive (4GB+)
  • Microsoft OS Disk (Vista / Windows 7)
  • A computer running Vista / Windows 7
Step 1: Format the Drive
The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.]
  1. Plug in your USB Flash Drive
  2. Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select "Run as administrator"
  3. Find the drive number of your USB Drive by typing the following into the Command Prompt window:
    diskpart
    list disk
    The number of your USB drive will listed. You'll need this for the next step. I'll assume that the USB flash drive is disk 1.
  4. Format the drive by typing the next instructions into the same window. Replace the number "1" with the number of your disk below.
    select disk 1
    clean
    create partition primary
    select partition 1
    active
    format fs=NTFS
    assign
    exit
    When that is done you'll have a formatted USB flash drive ready to be made bootable.
Step 2: Make the Drive Bootable
Next we'll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
  1. Insert your Windows Vista / 7 DVD into your drive.
  2. Change directory to the DVD's boot directory where bootsect lives:
    d:
    cd d:\boot
  3. Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I'm assuming that your USB flash drive has been labeled disk G:\ by the computer:
    bootsect /nt60 g:
  4. You can now close the command prompt window, we're done here.
Step 3: Copy the installation DVD to the USB drive
The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you've copied all of the files the disk you are ready to go.
Step 4: Set your BIOS to boot from USB
This is where you're on your own since every computer is different. Most BIOS's allow you to hit a key at boot and select a boot option.
Computers & Internet Logo
my cd/dvd drive G:\ (hl dt st rw dvd gcc h21n version.1.00) does not reads windows 7 dvd .. and it only reads cd-r/cd-rw.... plzzz help i want to install windows 7... plzz help...
It sounds like your drive is having issues, you can always install windows 7 from a flash drive (so long as your computer supports booting to one). Instructions on setting this up are here: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/ You will need to do this from a computer with a working DVD drive to transfer the info to a flash drive.
Jun 28, 2011 | Computers & Internet
4 steps to reset lost Windows 7 password
Forgot Windows password? it is your better choice to use windows password recovery 6.0, a efficient and highly appreciated software on Windows password reset. GO TO its official site for more info
Nov 09, 2010 | Computers & Internet
how create a bootable pen drive in win 7
hi ashok, i am happy to help you, just follow this steps
Procedure : -
1. Insert your USB flash/pen drive to your system and backup all the data from the USB as your USB drive will be formatted during the process.
2. Now download WinToFlash tool (free) from here.
3. Run the tool, and browse to your Windows 7, vista , or XP DVD files (make sure that your USB drive letter is correct).
4. Click Create button to begin the bootable USB process. Wait for few minutes to see the bootable USB.
5. That's all! Good luck
Jan 21, 2011 | Computers & Internet
What tool do you recommend if you forget your VISTA password?
For recovering Windows logon Password safely, I recommend software program Windows Password Seeker. Not only support XP/Vista/2000/NT, but also compatible with windows 7, it works perfectly to remove Windows logon Password. I wrote it to a Usb memory card. Booting up and clearing my password within just 4 minutes. You can Search Windows Password Seeker or download it from:http://www.passwordseeker.com
Aug 28, 2010 | Microsoft Windows Vista Ultimate Edition
massstorage
This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it.
Required:
· USB Flash Drive (4GB+)
· Microsoft OS Disk (Vista / Windows 7)
· A computer running Vista / Windows 7
Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator”
diskpart
list disk
The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1.
Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below.
select disk 1
clean
select partition 1
active
format fs=NTFS
assign
exit
When that is done you’ll have a formatted USB flash drive ready to be made bootable.
Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
Change directory to the DVD’s boot directory where bootsect lives:
d:
cd d:\boot
Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer:
bootsect /nt60 g:
You can now close the command prompt window, we’re done here.
The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go.
This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option.
I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
Jan 23, 2009 | Computers & Internet
323 people viewed this tip
David Payne
David Payne
