Tip & How-To about Computers & Internet
Windows 7 Forgot Password, How to Reset Password to Login Computer?
Today, Windows 7 is almost the most popular system for Windows, as the big user of Win 7, the issue of Windows 7 has also been increased, here just talking about the problems of forgot Windows 7 password, if this happens to you, what would you do to reset Windows 7 password for accessing to your computer again?
So common problems for us, maybe you have been troubled with forgotten Windows 7 password, or it occurs to you now, if so, you would not be anxious, there are some easy ways for you to reset your forgotten password on Windows 7.
Method 1: Try to remember your forgotten or lost password
When your Windows 7 can not recognize your password, it appears you have forgotten the password, and you can not access to computer to get files out. The first suggestion is try hard to remember your password, seeing your password hint whether to help you recall your lost password, and you need to be aware of the caps lock key is on or off, input the correct letter on lowercase or upper case.
Although it is not so efficient way to get into your computer, but you need to try to remember it and then decide whether to use the below method to reset your forgotten password.
Method 2: Windows password reset tool
When talking about forgetting Windows 7 password, you may refer to hack tools, this Windows password recovery tool is just to reset Windows password to let you re-access computer, it would not change your computer settings or damage your data.
Hearing about Windows Password Breaker? It's just a useful tool for lost password reset, it supports for your Windows 7 password reset, and also for other Systems: such as XP, Vista,2000,2003,2008, ETC.
see how to use Windows password Breaker to reset Windows 7 password: You need to download it from its Official site, then install it on any computer and run the program, it would help you create a Windows password recovery DISK or USB to reset password for a locked computer. Easily and efficiently.
When your Windows 7 password is lost or forgotten, you can try the methods for your forgotten Windows 7 password reset, with Windows Password Breaker, you can get into your computer within 5 minutes.
Computers & Internet Logo
win 7 blue screen of death on shutdown? happens on one in five shutdowns the others take several minutes (10) to complete the process.
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 16, 2010 | Dell Computers & Internet
i hav an acer 5230e ,i want to install window xp but on window setup it shows blue screen error nd appear plz remove newly installed drive nd chkdsk on run /////////////tell me wht i do?
heeey dude ! I had the same problem.. and I just solved out how to fix the problem !.. the only thing you have to do is: Go to your Bios, and switch from SATA to IDE, and then it will be fine :-)
Apr 05, 2010 | Acer Computers & Internet
I have a WNDR3300 and a desktop running XP. When I try to connect wirelessly, I get the blue screen of death. Two other PCs (both running Vista) are working fine
Its may be of low virutal disk space increase it at right click on mycomputer --> click on properties --> select advanced --> under performance click on settings the top most one --> then click on advanced again --> under virtual memory click on change --> select the operating system drive and increase the value and click on set and click on ok --> ok if this dosent solve the problem then the issue might be with your operating system got corrupted better you reinstall your operating system
Mar 25, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
513 people viewed this tip
David Payne
David Payne
