Tip & How-To about White Sewing White 4400 Computerized Sewing Machine
A new user guide from a novice covering beginner errors
I had to find most of these out the hard way. I am a beginner myself, and this was a difficult machine to learn on. But here are common solutions to the most common problems.
-Machine makes a clunking noise, claims there is a thread error when there isn't, and refuses to work.
-Oil your machine! Oil is provided in the small white kit (pierce the tip with a needle for controlled flow), and the manual gives you specific points to place one drop of oil. Oil that baby up and it goes right back to work!
-Machine causes thread to bunch under the cloth.
- Three possible solutions. 1- Use more stabalizer. This machine does not like to work on light weight or stretchy materials. While making a design for a quilt, i had to triple my stabalier to get it to work. 2- Use a different type of bobbin thread. I used the normal walmart kind of polyester everyday thread, and I hardly got it to work. Now i have a polyester thread that is super soft and much thinner, designed for embroidery. Works like a dream. 3- Make absolutely sure that your presser foot is UP when you thread your machine. I didn't think this would be such a big deal but it really is. Proper threading is 3/4 of my personal errors.
-Machine causes bobbin thread to show on top
- Two solutions. 1- Your bobbin is not threaded properly, and is most likely backwards. 2- your tension is too high. For most fabrics I use only a 4 or maybe 5 max.
Most of these errors are covered obscurely in the manual. Experiment a little and go through your manual again. If you can find your book manual, there is another copy on .pdf on your driver disk you can read or print. I haven't found a copy online, but I hope to post one soon.
This machine has been very frustrating to learn on. But hang in there! All machines have quirks, and this one needs maintenance more often than most. But it's versatility makes it worth the effort.
White Sewing White 4400 Computerized Sewing Machine Logo
Can I do stippling on my 400xl
This is free motion quilting. There are a ton of web sites and videos available. You'll need a darning or free motion quilting foot for your machine. Drop the feed dogs. If you are certain you want to do free motion quilting, a Supreme Slider helps you move the fabric.
https://www.amazon.com/Supreme-Slider-Motion-Machine-Quilting/dp/B007XGITA2
Learn How to Free Motion Quilt Stippling
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners 10 Tips
Free Motion Quilting Beginner Tutorial 1 of 4
Mar 07, 2017 | Sewing Machines
need pattern instructions for 3752 Simplicity apron
Depending on how old that pattern is, you might, possibly, get the primer from the company if you email them or call them.
There are any number of sewing forums where you might post a request and ask if anyone has it and can copy it for you. I got a primer that way once myself. There are some sites that sell vintage and out of print patterns and you might find another copy of the entire thing that way. Easy has some vendors with this kind of stuff. Try a google search.
It's not a very difficult pattern unless you are a beginner sewer. Maybe a friend with more experience could assist you to cut the pieces and assemble them?
Nov 02, 2016 | Simplicity Sewing Machines
Janome 1600P DBX
You need to drop the feed dogs, install a darning or free motion quilting foot (make sure the presser foot is lowered). Because you will not be using the machine to move the fabric, the stitch length selection is of no importance. Make sure the stitch width is set to zero. You should test FMQ on a scrap quilt sandwich of the same makeup of your project, ie quilt fabric with batting sandwiched between. The upper tension should be set so that both threads meet in the middle of the quilt sandwich. Because it is FMQ, some extra adjustment may be needed.
Once the tension is where you want it, you can practice FMQ until you can move it smoothly in conjunction with the machine speed.
Practicing on a white board with erasable markers is a handy way to learn to move smoothly. The most difficult part of free motion quilting is learning to move the fabric smoothly. Do NOT lack for practice as that is the only way to improve. Those people who make it look simple have been doing it for years!
Free Motion Quilting for Beginners Part 1 Video from Sewing with Nancy
Oct 31, 2016 | Janome Sewing Machines
trying to teach myself how to use this machine
hi! there,
watching then you learn,on internet explorer
type the address of www.youtube.com the on search box type "sewing machine" then there are slide show for sewing on beginners like you,you will learn a lot here just follow the instructions although it not the same like your machine but it near to similarity.happy viewing and learning don't forget to rate me,anything goes on feel to log in to fixya nothing is impossible. thank's
Apr 09, 2009 | Singer 1725
1,368 people viewed this tip
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
