Tip & How-To about Cell Phones
Not working camera and bluetooh for nokia
Camera and bluetooth isnot working...Just type *#7370* nothing more ok...format it *#7780#
Cell Phones Logo
i forget my security code and i want to recover
From howardforums.com posted by rambo47:
Nokia X2-01 Format and Factory Reset Code
1.Nokia X2-01Soft Reset
This will return back your X2-01 to its factory setting :
1. Dial or Key in *#7780#
2. Press Ok/Yes
This soft reset mode will not delete/harm your important data or applications, it simply restore the .ini files of the Nokia X2-01 ROM
2.Hard Reset Nokia X2-01:
1. Dial or Key in *#7370#
2. Press OK/Yes
3.Another alternative method you can try it if both method mentioned above not working. The method is pressing and holding down button *+3+Yes button right after your phone is turned on.
Sep 02, 2012 | Nokia X2-01 Black/grey Unlocked Phone
format1110i
There are two types of reformatting you can try Soft Format and Hard format.
Please see below instructions:
Press *# 7370 # Soft format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a software RESET. (however still another inquiry comes before.) NOTE! If the Akku to 75% are loaded at least, Akku do not only accomplish during the procedure under any circumstances remove! The procedure takes some minutes (approx. 3-4), is absolutely waiting! This is "only" a soft format... Hard format with "green, 3, *"... see below.
Hard format Green call button, *, 3 Hard format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET. Also known as the "3-fingered salute".
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
A VERY HELPFUL RATING IS APPRECIATED, Thanks
Regards, Nerdierob
Jun 04, 2011 | Nokia 1110i Cellular Phone
my nokia n95 would not turn on, placed it on a dry surface over night a, next morning would not turn on even when on the charger
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:Soft reset code *#7370#Hard reset code *#7780#If the hard format code mentioned above does not work, try the following manual method to hard reset/format Nokia N95:*Turn off the mobile device. Then press and hold "3", the "Green button" and "*" - Turn on and keep holding the keys until the mobile phone restarts and prompts you to enter detail
May 11, 2010 | Nokia N95 Cellular Phone
nokia n70 camera and bluetooth is not working
format it *#7780# or 3 key format calling+*+3 in off state then same time while keys pressed on the mobile leave keys while display shows formatting
Mar 22, 2008 | Nokia N70 Cellular Phone
153 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
