Tip & How-To about Microsoft Windows Vista Home Basic for PC
How to make your volume icon show up on your toolbar for Windows Vista
If your volume icon on the bottom right side of your screen is missing for some reason and you can't seem to get it to re-appear then this tutorial will help you get it back!
This tip is for Windows Vista-
1) Open your start menu and search for Regedit.
2) Open the Registry Editor
3) On the left side scroll up to the top
4) Open the folder HKEY_CURRENT_USER > Software > Classes > Local Settings > Software > Microsoft > Windows > Current Version
5) Now if there is already a folder in Current Version you should right click and delete it. Now right click the folder Current Version and choose to make a new folder. Name the folder "TrayNotify" (The text is case sensitive so make sure to enter it exactly how I typed it.
6) Now exit out of the registry editor and press CTRL+ALT+DELETE
7) Open your task manager and go to the processes.
8) Find explorer.exe and right click and end the process.
9) Parts of your screen will disappear, if they don't re-appear then choose File and Run.
10) In run type in explorer.exe
11) Now your volume icon should be back!
I hope this helped!
Microsoft Windows Vista Home Basic for PC Logo
how do I get my sound to work on my laptop
Anonymous - Depending on your type of laptop, there may be a volume wheel on the side of the laptop or a speaker Icon on the bottom of the screen to click and adjut. It may be that it is missing. Right click near the Time on the bottom right of the screen and select Properties. From this window you can check to make sure the Sound icon is set to ON or Restore Defaults near the bottom. Hope this helps.
Sep 28, 2014 | Toshiba Satellite Computers & Internet
How do I turn up the volume control IPhone 3GS?
when you hold the Iphone in your hand with the round button with the square inside it on the bottom of the phone. turn the right side of the phone down to the floor while you do this look for 3 buttons on the side of the phone the TOP button must be pushed upwards at all times this flip switch is your MUTE switch pushed down it is in must mode switched up is sound mode.
Below this is 2 buttons the button just under the top flip switch is volume up the other one is volume down there ya go.
Please rate my solution and leave testimonial this is how i earn my achievements thanks in advance.
Apr 22, 2012 | Apple Cell Phones
hi at the bottom of my screen i use to have a volume icon and i could click on it to say how high/low i wanted it but for some reason it has disapered and i got to the control panel to change it and it would allow me to click i would like to no how i can get that icon back to the bottom of my screen?
@georgia_9
If the volume icon is just missing, try the following:
For Windows 7
1. Right click on the System Time at the notification area (bottom right hand side) and choose Properties. It will then give you a window for the System Icons, check Volume on the list and click ok and that should fix it.
For Windows Vista
1. Right click on the Taskbar, choose Properties
2. Go to the Notification Area Tab then check Volume then hit Ok.
If the above troubleshooting steps still won't work, try this guide.
Good luck.
Sep 06, 2011 | Computers & Internet
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
Apr 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
volume control is missing
I am going to guess that you are talking about the volume control button on the bottom right hand side of the screen right? Did you recently install a new operating system or upgrade? No worries either way! Returning the volume control slider to the bottom right hand side of the screen is an easy task. I will walk you through it.
To return the volume control to the desktop screen, we need to go into the control panel. If you already know how to get to the control panel, please go there and find the ICON that says "sounds". If you don't know how to get to the control panel, follow these steps:
(Please note that the instructions below are for a person with the classic taskbar set up only)
Go to start at the bottom left side of your screen and click on it. Then slide up to "settings" and move to the right until you see control panel and click on it.
In the control panel, locate the ICON that says "sounds" and click on it. You will find the volume control option locate here. Make sure that sounds are enabled. You should see a choice in your current scound sceme that says something like "windows default" or similar.
Hope this helps?
Dec 06, 2010 | Microsoft Windows XP Home Edition
902 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
