Tip & How-To about Microsoft Xbox 360 Console
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
