Tip & How-To about Computers & Internet
How to Set up and Numark Controller with Virtual DJ
If you Purchase a Numark DJ Controller, Theres a good chance it comes with VDJ. This is a Very simple Process but for some it may be hard. First Take the CD that Came with your controller, Some might have Drivers, others just a copy of VDJ LE . Insert disk into drive and follow the on screen instructions. once that is done. Plug your controller into your computer and VDJ should Recognize it and you should be all set to go. If it doesnt Recognize it click on Config and then under sound options choose Numark, click apply and there you go you are up and running.
Computers & Internet Logo
I need virtaul Dj LE serial number for mixtrack pro
If you bought mixtrack with serato and want to change to vdj just go to
numark.com, download vdj le plugin, disconnect from the internet, install program, run installion, when asked for serial num enter:
6JDB-UFRV-X53S4
go to configuration and disable anything that would connect the program to the web, otherr wise it will not work any more
Mar 01, 2012 | Numark Industries Numark MixTrack Pro DJ...
I cant get the djio to play through my mixer
i have the same problem. My wild guess is incompatible dj software and numark drivers. i am using vdj pro 7 but i tried to downgrade to 5.02. and use single output ---------- headphones -------------- two cards, and assigned them to numark usb audio device, and the sounds goes thru my mixer. but when i use the vdj version 7 or higher cannot produce a quality sound. it got some noise coming out.
Apr 11, 2011 | Numark DJ/iO Sound Card
I have put the sierial number but still the numark contolar is it not active
The Controller is plug and play It will Work with or with out serial number you need to make sure you are using either VDJ or Traktor
Feb 15, 2011 | Numark MixTrack DJ Software Controller
141 people viewed this tip
David Payne
David Payne
