Tip & How-To about Cell Phones
Some self-help for Cell Phones
Before asking your question here are some easy steps to take that might solve your problem
1. Make sure all cards and your battery are fully in. (SD cards, SIM cards and batteries can all easily come out on some phones) 2. Restart your phone and check to make sure airplane mode are turned off 3. Make sure the phone has been activated with your cell phone carrier 4. Plug it in a charger to make sure it isn't a battery problem
Cell Phones Logo
my kodak easy share cd14 is showing "lens problem
This problem happens because oflong time no using/ Dust or Lens guide pin damaged. If the lens guide pindamage then there is no chance for repairing . Only solution is replacing thelens. For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if thecamera does not start working then you need to visit service center forreplacing the Lens or Repairing. But before repairing ask service center theapprox cost. if they told you to replacing the lens then do not do that.Because a new lens & service charge cost you near about a new camera price.So best is buy a new camera. If you have any more questions ask me I fell happyto answer your question. Thank you.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html - - - Doit your self lens fix
Oct 26, 2011 | Kodak EasyShare CD14 Digital Camera
it says low batterie when there new and there is a fish on the screen
Sorry not quite sure what you mean by a fish on the screen, but try these steps for solving the no power issue:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
Dec 31, 2009 | Kodak EasyShare C300 Digital Camera
ok so my camera turns on the light is on so its charging but when the light goes off it doesnt turn on. what does that mean
I'm not sure exactly what it means, but here are a few steps to solve the issue. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 31, 2009 | Kodak EasyShare M863 Digital Camera
BATTERIES GO DEAD AFTER TAKING ONLY A FEW PICTURES. HAS DONE THIS SINCE IT WAS NEW
Here are the steps:
Good luck I hope this will solve your issue
Dec 05, 2009 | Kodak EasyShare C340 Digital Camera
Have a Kodak Easy Share and when you try to turn on, the blue button turns on and then off and the lens wouldn't open. Has new battery....
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Without the memory card,turn on your camera.
Contact KODAK:
Dec 01, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
198 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
