Tip & How-To about Nintendo Wii Console
How to connect your Nintendo Wii to the internet
In this tips and tricks guide I will go over the steps you will need to take if you wish to connect your Nintendo Wii to the internet. If you want to connect wireless you will need to be within range of a wireless access point. If you wish to connect via a wired connection(Ethernet to modem or Ethernet to router) you will need a Wii LAN adapter which is sold separately.
-Power on the console and press the A button to reach the Wii menu. At the menu, use your remote to select the Wii button at the bottom left.
-Now select "Wii settings"
-Now, hit the arrow on the right side of the screen to go to the next page and select "Internet"
-Select "Connection 1: none"
-Select "Wireless Connection" then select "Search for An Access Point"
-Select "OK" then the Wii will display all the wireless access points(wireless routers) that are in range.
-Select the wireless access point you wish to use.
-If the access point requires a security key, you will need to enter this key in. This key is set when you first configure your wireless router.
-Select "OK", then "Save Settings", and then "Yes".
At this point your Wii will now test the internet connection.
If you are using a Wired connection then you can connect the Wii directly to the router or modem and not use WiFi. Wii LAN Adapters are sold separately. If you have the LAN Adapter, follow the steps above up to the point were you select a connection type. You will select "Wired" instead of "Wireless. The Wii will now test your internet connection.
I hope this guide has helped you connect your Wii to the internet. Enjoy!
Regards,
G33k
Nintendo Wii Console Logo
how do you connect the wii to the internet?
You need to have a wireless internet connecrtion available, then via the Wii system menus, go to the "Internet" option then set the paramaters for your wireless internet connection on the screens.
Mar 14, 2011 | Nintendo Wii Console
Wii Internet Connection
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Jan 13, 2009 | Nintendo Wii Console
cant connect nintendo wii to internet
Jan 07, 2009 | Nintendo Wii Console
Wii wired internet connection problems
if you have all of these
Requirements to Connect the Wii Console Online with a Wired Connection In order to connect the Wii console online with a wired connection, you will need the following:
  • A Wii LAN Adapter (where to buy)
  • An active broadband internet connection, such as DSL or Cable.
  • A compatible Internet Service Provider (ISP). Some ISPs require a sign-in every time you connect online, or are otherwise incompatible. Contact your ISP for more information.
  • Either a cable modem or wired router with an available ethernet port. (DSL users: while some DSL modems may be compatible, our experience has shown that many are not. We recommend using a router.)
  • An ethernet cable.
then go here for more information
http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wdRouter
this information was found on nintendo's customer service website
I hope you find it useful
Dec 29, 2008 | Nintendo Wii Console
wii internet connection
This is appearantly a common problem with the Wii. I got this information right off their Support Website. Error Code: 50231
The Wii console's internet connection settings have not been configured yet. In order for the Wii console to connect online, you must first go through a quick setup process to connect to your home network.
If you need assistance, we can walk you through the process using our step-by-step guide that allows you to follow along. Please click here to begin.
I hope this takes care of your problm.
May 11, 2008 | Nintendo Wii Console
3,221 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
