Tip & How-To about Computers & Internet
Ram errors, OS install errors, BSOD
These can all be cause my corrupt ram to tell if your ram is corrupt download
memtest from memtest86.com you want the bootable cd image file
burn this file onto a cd and then boot your computer from cd either setting
cd drive as first boot device in BIOS or hitting f12 as computer boots and in the quick boot menu selecting the cd drive
when the memtest program boots up start the memory test
if the test fails the corresponding ram module will need to be replaced
hopefully this helps
regards
djbr1ck
Computers & Internet Logo
i have added a 2 gigabyte ram to my newly bought laptop and when i want to install windows xp it gives the blue screen
Does it give the blue screen with the old ram memory?. You can go to http://www.memtest86.com/. Memtest 86 is free software to test the memory RAM of your computer. You will have to download the .iso file, burn it in a cd, and reboot. This is the only way to test the memory ram to stay 100% sure that it's not corrupted. If it's not corrupted, then check the ram memory specs speed, and latency. They must have the same speed and equal latency-or better- than the older ones.
Jan 03, 2011 | Acer Travelmate 5742 Notebook
set up problems
Unfortunately you'll need that CD to fix the issue, the only alternative is a lengthy process through the command prompt, which isn't even a guarantee. The reason you need the CD is so that you can restore your boot files with a fresh copy, as yours have become corrupted. Replacing the corrupted files is the only option.
May 05, 2009 | Dell INSPIRON 6000 CENTRINO...
ram failure notice on bootup....what's causing....
Not easy to say what it caused it, but if its bad the problem will be solved whit replacing it.
To be sure you can always run a memtest, download the program version from the site below, burnt it on a cd, reboot from your cd-driver and let memtest check your memorysticks.
Dec 10, 2008 | Panasonic TOUGHBOOK 18 C9/900...
Hp xw 6000, keeps shuuting down during initial boot up.
reseat ram if not i'd say to take 1 stick of ram at a time and start the computer with such might be a ram issue or run memtest 1.7 which can be downloaded here http://www.memtest86.com/ boot to cd once downloaded and burned to test ram
Mar 19, 2008 | HP XW6000 PC Desktop
Will not reinstall
download, burn and run the bootable memtest cd or dvd, boot from it and it will run tests your RAM.
http://www.memtest.org/
I have run into similar problems with faulty ram.
Feb 23, 2008 | ASUS A6U Notebook
218 people viewed this tip
David Payne
David Payne
