Tip & How-To about Computers & Internet
Reformatting and Reinstalling the Operating System
Sometimes it is necessary to do a complete reinstall from viruses or as a computer just gets bogged down by software over time. Here are some steps to have a successful experience.
1. Backup anything on the computer that is important to you, if you don't back it up your gonna lose it. Popular ways to do this are: CDs, USB drives, Online. Just backup your data somewhere safe before proceeding no one likes losing all the pictures of their loved ones that were on the computer.
2. Make sure you have an operating system to install back on the system. You need a disc containing an operating system such as windows XP, Vista 7, etc.
3. Make sure you have all the drivers for your system see this tip here about drivers http://www.fixya.com/support/r9197619-all_about_drivers
4. Boot your computer from the CD. The computer will have to be set in the BIOS to boot from CD before the HDD or alternatively you can usually hold f12 as the computer is booting up to display a menu where you can select the CD is the boot device.
5. The Operating system installer will load and dependent one what operating system your installing will look different but the general idea is the same. You want to overwrite the old install with this one completely formatting and erasing all past data.
6. The installation will format your drive and begin the operating system deployment it may ask you about some configuration settings along the way answer them.
7. The computer will boot into your new operating system install you will now want to install all the drivers your downloaded previously so that all your hardware functions correctly.
Congratulations your backup and running as simple as that :P
hope this helps you
regards
djbr1ck
Computers & Internet Logo
how can i remove virus
Removing viruses, though technical, is yet a very simple process if all the required steps are properly followed.
The basic steps are:
  • Buy or download a reliable antivirus software
  • Install the antivirus software
  • Update antivirus software with the latest virus definitions
  • Perform a complete system scan
Install an Antivirus Program in the System What is Antivirus program? An antivirus is a program that searches for, identifies and removes potential viruses existing in the computer system.
Antivirus software: Some of the most commonly and reliable antivirus programs available in the market are -
  • Symantec Norton antivirus
  • AVG antivirus
  • McAfee Scan
  • Microsoft Antivirus
The antivirus software should be updated regularly to retain its effectiveness.
Before installing the antivirus, close all open applications and terminate any suspicious processes using Task Manager. Sometimes, you may need to boot into safe mode or safe mode with command prompt to delete suspicious programs and references to them in the Windows Registry (run regedit from the command prompt to open the registry editor).
Search engines are excellent tools to find out whether a certain process is harmful or not. You can also get steps on how to remove a specific virus manually.
Removing the virus beforehand might be necessary, as some viruses will not allow an antivirus to operate. However, if you are not successful, you may still continue with the installation.
Scan the System to Identify and Locate the Virus Usually, the antivirus will run automatically when the system reboots after the installation. Therefore, it might identify the virus automatically. Moreover, you may want to run a quick system scan to locate the virus.
Troubleshooting the Virus Infected Areas After the antivirus identifies the infected areas, the next step is to rectify those areas.
Methods of Eliminating Viruses
Generally, the antivirus adopts one of two methods to eliminate the virus:
  • Removing the virus - When the virus can be easily identified and can be removed without affecting other files, then the antivirus removes it from the host place.
  • Quarantine - his is done when the virus cannot be easily identified removed from the file and the removal of virus means the removal of the complete file. In this method, although the virus is not eliminated, it is rendered inactive by moving the file into "quarantine" and renaming it.
Perform a Full System Scan Even after the virus is removed from the system, the next step is to scan the whole system to ensure that no infected files remain.
Aug 17, 2011 | Computers & Internet
getting late started and many virus
If your system will not boot up correctly and you suspect a virus is the problem, a recommended solution is to start your computer in safe mode and run a virus scan. By running your computer in safe mode, non-essential processes do not start and non-core components are disabled. In other words, only the minimum necessary programs will load. Tough to remove viruses, spyware and other malware usually have no chance to run and disrupt your system and can more easily be removed.
To run a virus scan in safe mode, you must have active anti virus software installed on your computer.
To run a virus scan in safe mode, follow these steps:
1.If your computer is on, shut it down
2.Power on your computer
3.Immediately after you power on your computer, repeatedly press the [F8] key (about once per second)
4.In the Windows Advanced Options Menu screen, use the arrows to select Safe Mode and presss [Enter]
5.Select your current operating system and press [Enter]
6.Select the user you would like to login under (if applicable)
7.When your system finishes booting, click the Start button on your task bar
8.Move your cursor over All Programs and navigate to your anti virus program
9.Click on your antiv virus program to run it and follow the anti virus program's normal steps to run a virus scan
10.After the virus scan is complete, Delete all detected viruses
11.Close out of your anti virus software
12.Restart your computer (it should start in normal mode)
Your Feedback is greatly appreacited.Thank you for using FIXYA.
Jun 30, 2011 | Computers & Internet
Heeeelp, ok no sales pitch for me, i run a small home business and need to get up and running again...I received a pop-up yesterday saying I needed to fix a virus-threat and malware, I kept saying no and my system stuck then my pages wouldnt load, so I restored my system and everything was fine, but I also loaded a new, updated Norton Security software and the scan resolved some malware that infested the computer, and everything ran smooth all day until now,,I had to restart the computer to try to get unstuck and now it just gives me a blank screen, no Welcome screen ever comes up and it says "Fatal Error", System shutdown, terminated..."
if you can...completely wipe out your hard drive and reinstall windows. if you need the stuff off of your hard drive...take it to a small local computer business and they will do that for you for cheap. sometimes you will save yourself a whole lot of time and heartache if you just completely reinstall windows and wieout your hard drive and write over it again. AVG or Avira is a free virus software program that has never allowed a virus on my computer.
if you ever get a message that ask you to run a virus scan without your initiating it then don't...there are so many of those damn scams. Good Luck.
Sep 15, 2010 | Computers & Internet
My computer is running slow and My yahoo messenger is not staying on the computer
maybe your attack by a worm or a virus try latest virus remover. if not so clean up software that are not necessary to use or you may reinstall the OS of your PC just be sure that you have a complete driver of it.
Jan 08, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
HP 6110xi
These errors are normally the result of a failed scan, a bad installation, communication problems or software conflicts. Check or perform the following steps until the problem is corrected. Step One: Restart the computer Close all programs and restart the computer. A task that Windows requires may have stopped running or available system resources may have decreased due to tasks left running. Restarting will refresh all Windows tasks as well as increase the system resources available. Step two: Verify that the cable is connected and the all-in-one is "On" Verify that the cable is connected correctly. If the cable is connected into a USB port on a keyboard, move the cable to one of the main USB ports in the PC. Some keyboard USB ports do not provide sufficient power to supply a device such as the all-in-one. Step three: Check the application If the error occurs while trying to scan from within an application (not the HP Director), verify that the software is set to select the HP all-in-one product as the TWAIN source. It may be necessary to reinstall the application to get it to recognize the HP all-in-one product as the TWAIN source. If the application is one of those listed in the "Scan To" tool from Settings in the Director, then try scanning to it from the Director. Step four: Windows XP only: Change the Compatibility Mode settings This step applies only to the following products and only in Windows XP. For other products, continue to Step 5. Change the Compatibility Mode setting for the HP all-in-one desktop icon can correct the problem. Right-click the HP product icon, and then click Properties . Select the Compatibility tab. Change the Compatibility Mode settings to enable running the program in Windows 2000 Compatibility mode, and then click OK . Turn off the all-in-one. Restart the computer. Turn the all-in-one back on. Step five: Check for the correct entries in the Device Manager Verify that the unit was installed on a DOT4 virtual port in the Device Manager. Right-click My Computer , and then click Properties . Select the Device Manager tab (Windows 2000 select the Hardware tab , and then click Device Manager ). Check the list of installed devices for references to DOT4 as shown in Figure 1. If there are no DOT4 references, the software has not installed correctly. If these entries are missing, the software did not install properly. Do the following steps to correct the problem: Disconnect the communications cable to the all-in-one and unplug the power cable to the all-in-one. Uninstall the HP all-in-one software. Step six: Check for communication problems between the all-in-one and the computer Communication between the all-in-one and the computer may have failed. USB cable connected all-in-ones: Check for USB port communication problems. Parallel port installed all-in-one products: Check for parallel port communication problems. Step seven: Check the computer to see if it is infected with a computer virus If the all-in-one prints but will not scan correctly and does not show any symptoms of communications problems, the computer might be infected with a virus. Some viruses try to disable virus scanning software and in doing so disable scanning from the all-in-one. If the scanning software works after installing the all-in-one software until the first time the computer is restarted, or quits working after a virus is discovered on the computer, there may be a virus related problem. Step eight: Uninstall and then reinstall the all-in-one software Do the following to uninstall and then reinstall the HP all-in-one software: Follow the steps in the " Removing the HP software " section below to remove the all-in-one software. Right-click My computer and then click Explore . On the left side of the Windows Explorer screen, locate and open the Windows or WinNT folder. Locate and open the Twain32 and/or Twain_32 folders. Remove all files in these folders other than files that end with a .ds file extension. If you cannot see any file extensions, click Tools , click Folder options , select the View tab, and then remove the check from Hide file extensions for known file types . Restart the computer and then reinstall the all-in-one software. When the installation of the all-in-one software is complete, shutdown the computer. Connect the communications and power cords to the HP all-in-one and verify that it is turned on and ready. Restart the computer. Step nine: Check for software interference There may be a task running in the background that is interfering. Try pressing the keys Ctrl + Alt + Delete at the same time. This should bring up the "Close Program" window. Highlight and end task on all running tasks except for Explorer, Systray, and tasks that begin with "HPO." Press Ctrl + Alt + Delete to bring up the "Close Program" box for each and every task. The "Close Program" box will disappear when End Task is chosen. Try launching a scan after all tasks are closed. If scanning works, then there is a software conflict. Restart the computer and repeat the steps to close down the tasks. Close down one at a time or in combinations and try scanning until the cause is found. If it is unknown what this task does, do the following: Search for the file using the Find Files and Folders feature from the Start menu. Right-click the task's program icon, and then click Properties . Refer to the information on the Version tab to locate the software vendor. Call the software vendor for assistance or uninstall the product if not needed.
Sep 19, 2007 | HP OfficeJet 6110 All-In-One InkJet...
293 people viewed this tip
David Payne
David Payne
