Tip & How-To about Microsoft Windows XP Professional SP2
How to open the default Bluetooth file transfer window in windows xp
1> Go to start
2> Click on Run
3> And type "fsquirt"
which will open the default Bluetooth file transfer wizard..
Microsoft Windows XP Professional SP2 Logo
hi i have acer aspire 5336-2524. i didnt find any bluetooth,can some body tell where i can find bluetooth.Thanks
Go to the task bar and Click Start,
Then Go to the Run,
Click and type This Command
fsquirt
Then Click OK and follow Instruction to the Wizard.
Jul 05, 2011 | Computers & Internet
i JUST WANT TO KNOW IF MY aCER ASPIRE ONE D250 HAVE BLUE TOOTH
Go to start->Run there you type "fsquirt" this wil open the default bluetooth file transfer wizard (In windows only). Click on next and select send file and once you click browse, it wil tell you whether the blue tooth hardware is already installed in your system or not.. I hope this wil help you.
May 14, 2011 | Acer Aspire One PC Notebook
bluetooth driver see in device manager already installed but there is no icons or programs found
Hi siddiquechan,
Please try opening the Run window by pressing the Windows logo and the R Keys. After that, please type fsquirt in the Run Window and press the Enter Key. This will open the Bluetooth File Transfer Wizard.
Hope this helps to transfer the files to Bluetooth Enabled Devices.
However, you may need to use the Additional functionalities of the Bluetooth.
If you required further assistance please get back to us with exact Model # of the Computer and Operating System installed in it.
Thanks...
Thanks for using Fixya.
Sep 20, 2010 | Computers & Internet
hyplinks do not work in Outlook 2007. they used to work, not sure what made them stop
Fix 1: Start by Resetting Your Default Browser Most times, I can fix my Outlook hyperlink problem by resetting my default browser to Internet Explorer. I start with this step even if I plan to use Firefox as my browser. The reason I choose this path is I’ve had better success and it takes me closer to my end goal.
To make IE your default browser,
1. Open Internet Explorer
2. Click Tools from the menu
3. Select Internet Options.
4. Click the Programs tab
5. Click the button labeled Make Default.
6. Click OK.
7. Test a hyperlink in Outlook to see if the web page opens in Internet Explorer.
Fix 2: Reregister Windows DLL Files Even after resetting your default browser you still can’t open hyperlink in Outlook, it could be one or more registry keys is damaged. The solution is to reregister some of your DLL files. The process may sound intimidating, but it’s easy. There are 6 files to register based on your system. Some configurations use shdocvw.dll and others use shdoc401.dll.
To reregister the DLL files,
1. Close all open programs.
2. Click the Start button.
3. Select the Run… command. Vista users can type “run” in the Start Search textbox.
4. In the Open: textbox, type regsvr32 followed by a space and the file name.
In the screen snap below, I’ve used the first file Shdocvw.dll.
5. Click the OK button. You should see a message showing the process succeeded.
6. Click OK to dismiss the message.
7. Repeat the procedure for the other DLL files.
  • regsvr32 Shdocvw.dll (Some system use Shdoc401.dll instead)
  • regsvr32 Oleaut32.dll
  • regsvr32 Actxprxy.dll
  • regsvr32 Mshtml.dll
  • regsvr32 Urlmon.dll
  • regsvr32 Shell32.dll
8. As before, test to see if your Outlook hyperlink problem has been resolved.
Fix 3: Reset the (NONE) URL File Types If you’ve gotten to this part, I have to figure your Outlook hyperlinks are still broken. Don’t fret as I have another fix to try. My guess is someplace along the line your file associations broke. This is the mapping Windows uses to a file type to program. A common mapping might be .XLS files with Microsoft Excel. In this case, we need to check URL mappings.
To set URL file associations,
1. Open My Computer.
2. From the Tools menu, select Folder Options…
3. Click the File Types tab. A long list of Extensions and File Types appears.
4. Scroll down till you get to (NONE) URL:HyperText Transfer Protocol
5. Click the Advanced button.
6. Select the bold open item. *
7. Click Edit…
8. Click the Browse… button
9. Navigate to where Internet Explorer is located. (For most PC, it’s at C:\Program Files\Internet Explorer\iexplore.exe)
10. Add a space and %1 to the end of the file name. (e.g. "C:\Program Files\Internet Explorer\iexplore.exe" %1)
11. Click OK.
12. Click Close.
13. Repeat the process for (NONE) URL:HyperText Transfer Protocol with Privacy.
* If open doesn’t show, click New and type open in the action box.
Back to Firefox (Optional) Once you get the Outlook links to open in Internet Explorer, you can change your default browser to Firefox. This should roll down to Outlook so any embedded hyperlinks will open in the correct browser.
To set Firefox 3 as your default browser,
1. Open Firefox
2. Select Tools from the menu
3. Select Options…
4. Click Advanced
5. Click the Check Now button
6. Click Yes if the default browser is not set.
7. Click OK.
Nov 20, 2009 | Microsoft Office Professional 2007 Full...
I have Aspire 4730Z acer laptop. but can't install blue tooth. when going to install driver from utility CD showing no device found. let me clear how can I resolve the problem
Method 1: Rename the Bth.inf file loadTOCNode(2, 'workaround'); Rename the %WINDIR%\inf\Bth.inf file to Bth.bak before you install or reinstall the third-party device or stack. When you rename the file, you prevent Windows Plug and Play PNP from using that INF file to install the Bluetooth driver that is included with Windows XP SP2. To rename the file, follow these steps:
  1. Click Start, click Run, type %windir%\inf in the Open box, and then click OK.
  2. Right-click Bth.inf, and then click Rename.
  3. Rename Bth.inf to Bth.bak, and then press ENTER.
  4. Install the third-party Bluetooth driver.
Method 2: Update the Bluetooth driver in Device Manager loadTOCNode(2, 'workaround'); To replace the Windows XP SP2 installation of the Bluetooth stack, update the driver in Device Manager. When you do this, specify your third-party driver. To update the driver in Device Manager, follow these steps:
  1. Click Start, click Run, type devmgmt.msc in the Open box, and then click OK.
  2. Locate the device.
  3. Right-click the device, and then click Update Driver.
  4. Follow the steps that appear on the screen in the Hardware Update Wizard to specify your third-party driver for the Bluetooth device.
Mar 05, 2009 | Acer Aspire 5610-4648 Notebook
1,585 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
