Tip & How-To about Microsoft Xbox 360 Console
How to connect your Xbox 360 to the internet
In this guide I will go over how to connect your Xbox 360 to the internet either via wired or wireless connection.
Wireless Connection
*For a wireless connection you need a wireless access point(router) and either a Xbox with built in wifi adapter or purchase a xbox wireless adapter*
-Turn on your xbox and go to "My Xbox" then go to "System Settings"
-Select "Network Settings"
-Select the name of your wireless network.
If you do not see your network, select "Advanced options" then select "Specify unlisted Network" then enter your network name.
Enter your wireless network security key. It may prompt you to update your console, select yes.
Wired Connection
*For a wired connection you need to use an Ethernet cable and plug one end into the back of your xbox and the other end into your router or cable modem.*
-Select "Test Xbox Live Connection", afterwards it may prompt you to update your console, select yes.
Now, you are connected to the internet and can enjoy xbox live.
Regards,
G33k
Microsoft Xbox 360 Console Logo
advent k200 wired xbox 360 internet
Make sure that your xbox account is connected to a Xbox live membership. If so go sign out, and then sign back in and it should Work.
Mar 24, 2013 | Advent Computers & Internet
how to get an internet connection for xbox live
Hello award ward,
To get a wireless internet connection for Xbox live, you will need a high-speed Internet connection such as cable or DSL and a router, gateway, or wireless access point (WAP) that is compatible
with Xbox live. If your XBOX360 console is first generation, you will also need a Xbox 360 wireless networking adapter. If you are using a wired connection, you will need a network cable. Plug the network cable into your router and the other end into your Xbox 360. On your Xbox 360 console, navigate to "MY XBOX" and then select "system settings" Next select "Network settings" and then select "Test Xbox Live connection" Select YES when the prompt appears asking you to update your software. After you become connected, there are two choices: Free membership of Gold membership. Once you are connected, navigate back to "My XBOX" and select your avatar and then select "Join Xbox Live" If you need any more help feel free to contact me. Thank you for using Fixya
michael34
Mar 09, 2011 | Microsoft Xbox 360 Elite Console
how do I connect 2 or more players with the xbox controller?
Follow these instructions:
  • Set up your Xbox Live connection by connecting your Xbox 360 to high-speed Internet. There are two options: connecting it to your network via Ethernet cable or connecting to your network via a wireless adapter. The simplest and fastest connection is connecting via Ethernet cable directly to your modem or router. If you must connect wirelessly, use the Xbox 360 wireless adapter, sold separately. See the Resources section below for connection tips.
  • 2
    Test your Xbox Live connection after connecting your Xbox 360 to your high-speed Internet. Navigate to the dashboard, select "My Xbox," choose "System Settings" then "Network Settings." Run the diagnostic test to confirm your connection works. Your Xbox 360 will offer troubleshooting tips if the test fails.
  • 3
    Create an Xbox Live gold account. Log out of all profiles then press the "Guide" button and choose "Join Xbox Live." Follow the prompts, entering your billing and personal information. You will also choose your gamertag during this process, which will serve as your online name and identity. Lastly, you will customize your profile. Your Xbox 360 will then create the account.
  • 4
    Insert your Xbox Live multiplayer game and open the game's Xbox Live multiplayer menu. Different games have different options but certain features remain the same across all multiplayer games. There is the TrueSkill ranked matchmaking system, which pits you against players of similar skill levels. There are also unranked player matches, where you can practice and hone your skills in a non-competitive atmosphere. Lastly, there is the quickmatch matchmaking system, which automatically searches for games for you, whether they are unranked or ranked.
  • 5
    Add and play with friends. Xbox Live allows users to add up to 100 friends. Add a friend by pressing the "Guide" button, navigating to the "Friends" tab, then selecting "Add Friend." Type in your friend's gamertag then press the "Start" button and choose "Send Friend Request." Your friend will need to confirm the request to complete the process. You can play multiplayer games with friends by opening your friends list and inviting them to a game lobby.
  • 6
    Communicate with friends and opponents using an Xbox 360 headset. The wired Xbox 360 plugs into your controller. Once it's plugged in, you can speak into microphone and listen to others from the ear piece.
  • Hope this will help...Your response is very much appreciated...
    Jan 21, 2011 | Computers & Internet
    I have a wireless router hooked to my computer & my son recently got a wireless-G USB adapter so that he can play his xbox 360 online. Will this work, or will we have to put the router on the xbox & the adapter on the computer?
    XBOX 360 will only work properly with a 'genuine' USB WIFI adapter designed specifically for it (and at an over inflated price IMO!).
    One popular way to play 'network' via the internet is to connect the XBOX 360 to your PC via Ethernet cable and have the PC connecting to the internet either via another ethernet connection or more likely via a Wifi connection which could be via your USB adapter connected to your PC and talking to your Wifi Router)
    Dec 26, 2009 | Computers & Internet
    Xbox 360 Connection to internet
    the IP address will fail when it is set on manual, rather than automatic. Be sure, once you enter it, it is set to automatic
    Jan 03, 2009 | Microsoft Xbox 360 Console
    2,145 people viewed this tip
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
