Tip & How-To about Motorola Mobility Clutch i465 Cell Phone
How to enter your PUK Code on a Motorola i-Series Cell (i465)
I got this info directly from Boost Mobile and it should be applicable to ALL Motorola i-Series cell phones.
1. Obtain your PUK code from your cell phone carrier or from the SIM card if you still have it 2. Turn your i-Series phone if it isn't already on. 3. Press the following keys in the following order:
*(star) # Menu (The 4 squares) 1
4. The menu to change your SIM Pin will pop up. Select that option. 5. Enter your PUK code (Mine was 8 digits) 6. Enter your new SIM PIN code (0000), (1234), or whatever you like. 7. Verify your new SIM PIN code (The same as you entered above)
And that is how you enter your PUK Code on a Motorola i-Series Cell
Motorola Mobility Clutch i465 Cell Phone Logo
need puk code for pantech crossover
PUK stands for Personal Unblocking Key. This is a unique eight-digit code specific to your SIM card. This is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack. If you do not have this then - Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give them your account details and they have confirmed your identity. For details to obtain the PUK code for the SIM card, please click on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Oct 15, 2012 | Motorola Mobility Boost Mobile...
how do you unlock a boost Motorola theory to use with T-Mobile
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 23, 2012 | Motorola Mobility Boost Mobile...
my boost moble keeps saying sim disabledby puk blocked. how do i fix it?
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Aug 21, 2011 | Motorola Mobility Boost Mobile...
i was given 585195589 as universal puk code for a motorola i465 boost moble handset. is the code accurate
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Oct 29, 2010 | Motorola Mobility Boost i415 Cellular...
how to unlock my pin blocked boost mobile i425 without calling the 1-800.....number
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times,
This code is OPERATOR specific and not phone specific and you have to call you operator and get PUK if PIN is blocked...
if you provide PUK code wrongly for 10 time, you sim may become useless, then you have to buy new SIM
NOTE: You should ask your service provider,get the PUK,
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Oct 29, 2009 | Motorola Mobility Boost Mobile...
2,695 people viewed this tip
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
