Tip & How-To about Computers & Internet
What to do if your USB is not detected on your PC...
Hi Everyone,
If you are experiencing problems with Windows detecting your USB drive (Storage, MP3 or iPod), follow these steps to get them back. These problems are usually caused by either viruses or a damaged sector on the drive itself. Formatting the drives after enabling them, would usually restore all the functions back to normal.
IF USING WINDOWS XP:
Follow these simple steps,
- Right-Click on My Computer, and select "Manage"
- On the Right hand panel select "Storage" - Double Click on it
- Double Click on "Disk management(Local)"
- Your disk will most likely show here with NO Drive Letter
To fix it, assign a new drive letter to it by doing the following:
- Right-click the drive, and select "Change Drive Letter & Paths"
- Press Add.. select a letter and hit OK twice - It should now be visible.
IF USING WINDOWS VISTA OR WINDOWS 7:
- Open the Start Bar (Lower Left Corner by default)
I hope this tip has helped you combat those pesky USB errors.
* If you found this solution helpful, please vote positively.
Computers & Internet Logo
error windows was unable to complete the format
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
Feb 26, 2014 | SanDisk Sansa Fuze MP3 Player
the device can not be detected in my computer
Hi there.... You can try other computer if they can detect the Sony Walkman that you have, if not being detected, have the device physically check.... if being detected by other computer, try updating the driver or software for that Sony device..
Thank For Using Fixya
Jun 03, 2011 | Sony Walkman NWZ-B135 MP3 Player
my sandisk e 250 one gb ipod is not detecting in ubuntu 10.04 but is charging
you must follow 5 steps
1) connect ur device to windows xp or windows 7
2) go to sansa website download sansa updater and install it
3) then follow instructions by sansa updater it will then automatically search and install a program for detection of mp3 player on ubuntu install that program its around 16mb .the software will do this you just follow this
4 after completing sansa updater instruction ,go to settings you can now see a usb mode then change to msc mode for detection in ubuntu
5 for detection on windows change to mtp mode
Oct 22, 2010 | SanDisk Sansa e250 MP3 Player
sandisk is not being recognized on my computer
SOLUTION 1 - Verify if minimum system requirement is met.
SanDisk card readers support Windows Vista, Windows XP SP2 and Windows 2000 SP4.
For MAC users, see
Troubleshooting USB device on MAC
SOLUTION 2 - Verify the reader's status under Device Manager.
STEP 1 - Connect the reader to the PC
NOTE: It is recommended that you plug your card reader to the back USB port on your PC to ensure that there is enough power from the USB port for the card reader to be detected properly.
STEP 2 - Check under Device Manager
1. Right-click My Computer.
2. Select Manage.
3. On the left pane, click Device Manager.
NOTE: The card reader will appear in two places: Disk Drives and Universal Serial Bus controls as USB Mass Storage. If there is a yellow exclamation point (!) or question mark (?) next to the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action, and then click Scan for hardware changes.
STEP 4 - Verify if the reader is detected
1. Double-click My Computer.
2. Look for the card reader under Devices with removable storage.
SOLUTION 3 - Try other USB ports.
A yellow exclamation point (!) under Device Manager usually means that the device is not receiving enough power. If the reader is not receiving ample amount of power from the USB port, it may not function properly.
SOLUTION 4 - Change the drive letters
NOTE: The SDDR-89 reader should show 4 drive letters under My Computer.
Mar 01, 2010 | SanDisk Sansa m250 MP3 Player
How to detect the pen dirve
A computer that is running Windows XP cannot detect a USB thumb drive, an Apple iPod, or an external hard disk drive....
for this please follow the complete step by step instructions
http://support.microsoft.com/kb/925196
Thank you
Dec 19, 2008 | Microsoft Computers & Internet
296 people viewed this tip
David Payne
David Payne
