Tip & How-To about Televison & Video
How to repair DVD (not eject)
My tips on how to fix the not ejecting DVD.
These are the steps on how to do a D.I.Y troubleshooting:
  1. Remove the cover of your DVD player.
  2. Look for the DVD or CD tray assembly.
  3. Remove the whole CD tray assembly by loosening all screws at the left and right corner of the CD tray assembly and also you need to remove the front panel of the ejecting tray to get the whole CD tray assembly away from the DVD player for further repair and check-up.
  4. Then look at the bottom of the DVD or CD tray and try to find out where's the motor that controls the ejecting tray.It is usually have a rubber O-ring or mini rubber belt that control the gear of ejecting tray
  5. Next,when you found the ejecting motor,try to look at the rubber O-ring or mini rubber belt condition,if it is cut/loosen or disconnected from the motor.
  6. If the rubber belt is in good condition,check the ejecting motor. There are 2 ways of testing the motor.
  • First,the resistance checking-you should have a ohm meter or multimeter (resistance or ohm range) point your (+/-) test prove to the terminal of the motor to measure the resistance.
  • Second is the actual testing in this procedure you need a battery 3vdc,connect the negative(-) terminal of the battery on the black wire of the motor and the positive(+) ,connect to the red wire.If the motor is not spin-up replace it with the same type,rating,voltage and value.
7. If you already done this procedure and the problem is still there
after you replace the defective parts,if any.The problem could be
the motor ejecting driver that found on the main board.This is not
for D.I.Y because of the parts inside main board is very sensitive
and hard to replace.If the trouble is on the main board you have to
replace the whole main board or buy a new player.
Thank you for reading my tips.
Televison & Video Logo
How do I remove a stuck DVD?
It sounds like your problem isn't the dvd is stuck, since it seems to be spinning up, it sounds more like your ejection system has stopped working for some reason.
To fix either you are going to have to remove the outside case of the dvd player and expose the internal chassis. There are anywhere from 4 to 8 screws holding it on on the bottom and back of the unit, Make sure the dvd player is unplugged before you remove the cover.
Once you have the cover off, if the dvd is simply stuck, you should be able to see what the issue is; is it misaligned in the housing was it inserted incorrectly, are there in fact 2 dvds in the player, etc, etc. Gently remove the dvd and replace the case and enjoy.
If you can't see any reason for it to be stuck it may be the ejection system. The eject system will have a belt and sprocket system to move the tray or push out the dvd depending on the player. Make sure the belt is on the wheels correctly and that the sprockets mesh properly. If you can't see anything wrong try testing the ejection system with the case off.
Make sure you don't have any objects in or touching the dvd player, you don't want to short out any of the components if a screw fell into the dvd player onto the mother board, etc. Plug the dvd player back in, make sure you don't touch the inside and try to eject the dvd. Watch the ejection system and you should be able to figure out what is going wrong. Once you have figured it out unplug the unit and put the items back together. If you can see that something is broken then you will have to determine if you can have it fixed or if it wouldn't be cheaper to simply ditch that unit and purchase a new one.
Hope this helps.
Oct 12, 2015 | Televison & Video
cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
my sony dvp sr200p cannot eject the disk inside. i tried all the 4-digit code but i failed.
From www.sony.com
Unable to eject a disc.Solution
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
    NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
Feb 29, 2012 | Sony DVP-SR200P DVD Player
6,347 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
