Tip & How-To about Televison & Video
Can I record downloaded films etc. from pc...LG RH177 (80 GB) DVD Recorder
No, you can't load them. You can do something else: copy the movies on an USB stick, plug the stick on the LG and play them from there.
Televison & Video Logo
i have a fat32 usb stick with but the bd370 could not play the movie
resave the file to your computer, and reformat using NTFS. retransfer to the stick, and it should work after that.
Jul 15, 2012 | LG BD370 BLU RAY PLAYER
can I record downloaded films etc. from pc direct to lg recorder?
Oct 25, 2010 | LG RH177 DVD Recorder/HDD Recorder
can i play movies off a USB in the tv's USB port, if so, how ??
OK, well I have used this many many times. You simply need to copy the Movie in any of the Formats that the set can use, and copy the Movie to the USB stick. When the stick is inserted, using the remote you simply "Select" that "USB Input" and select the Movie, and select "Play", IF the right Format, has been used, the Movie will "Play" as if it was a DVD.
Consult your manual. link below.
http://www.tacp.toshiba.com/dvd/product.asp?model=47HL167
Jul 21, 2010 | Toshiba REGZA 47HL167 TV
usb problem lg pq2000
pq2000 does not have a movies option for USA, the pq3000 does. I also have the 2000..
Feb 18, 2010 | LG 42LC2D 42 in. LCD HDTV
will playstation 3 play blu ray movies off usb memory stick? all other movies worked but blu ray one didn't work.
the PlayStation 3 can read just about any usb memory stick and play can movies from them, since a usb's bandwidth is significantly lower then the ps3 hard drive it's recommend to copy the movie to the ps3's hard drive.
also it matters how the movie was converted. some converted movies wont play on the ps3 no matter what codec your using to encode the movie with.
Jun 03, 2009 | Sony PlayStation® 3 (80GB) Console
460 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
