Tip & How-To about Jenn-Air JGR8855BDS Gas Kitchen Range
Bought a used Gas oven but top Burners are having low flames..
Hi
i have model#JGR8855ADS
on top burners flames are very low..even high performance one is low..what sould be the problem...pls help me ???
Jenn-Air JGR8855BDS Gas Kitchen Range Logo
I have a heatilator gas fireplace model gcdc60 and the flame is not high anymore. This fireplace has two settings low and high. The high setting is like having low on and the low setting is almost not there. I have removed the logs and vacumed the burner. I even ran it with out the logs to see if flame was restricked. Is it the burner bad or something else
Take a thin stiff wire and run it thru each flame port of the burner a few times each then if you can take a vacuum after setting it right on the ports-tap on the burner with a object while vacuuming it-if that does not work -is there a place that looks like a nut over each flame port? if so spray with a lubricant like WD40 to loose the nut and remove and clean flame ports that way and vacuum it then same way then
Sep 30, 2017 | Home
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Flame going low on range cook-top
Check your gas supply is not running too low and then check for leaks, Let me know if this helps.
Jan 02, 2010 | Tappan TGF320 Gas Kitchen Range
Lack of heat
The plates protect the burners and help disperse the flame more evenly across the grill surface. Make sure the tank is completely open (knob on top of tank) and that when the burner is turned up to high, the flames out of the burners are about 1 1/2 to 2" long, mostly blue in color. If they are smaller, and the tank is open all the way, the regulator hose may be defective.
Jun 19, 2008 | Uniflame 200209 Open Flame Patio Heater
1,868 people viewed this tip
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
