Tip & How-To about Computers & Internet
PDF - How To Create One
To create a PDF all you have to do is simply download a PDF printer add on.
When you create a document or image etc.. click the print button and select the PDF software (It will display as a print).
I would advise PrimoPDF i have been using it for many years now and creates incredible PDF's with many options such as passwords, text PDF, hign resolution PDF ect.
Once you have download the software, open the file you wish to have as a PDF (This will be a new file and not overwrite the original file) click print and chose PrimoPDF from the printer drop down menu.
PrimoPDF will then lunch it conrol panel where you select options such as the once stated above including where you would like to save the PDF
PRIMOPDF
Computers & Internet Logo
I want to print mirror image for heat press
If you need a quick fix for printing a mirror image on your printer, download and install CutePDFwriter http://www.cutepdf.com/products/cutepdf/writer.asp into your printers. This is a free download. Choose the printer preferences.Click the "Advanced" button. Click on the + sign next to "PostScript Options". Change the Mirrored Outpout: from No to Yes. This will let you print to a PDF file without messing up your original document. You can then print the PDF file to your paper. This may not fix your printer but it is a quick fix to do what ever and then you don't have to make the changes again if you want to print the item, picture, text, etc. again. Hope I have helped.
Dec 11, 2013 | Ricoh SP C430DN Laser Printer
hp 4700 won't print pdf
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows XP platform:
  1. Choose Windows Start button and open the Printers and Faxes window.
  2. Right-click the QuickBooks PDF Converter icon and choose Properties.
  3. Click the Ports tab. Click the Add Port button.
  4. Select Local Port. Click the New Port button.
  5. For the new port name, enter PDF1. Click OK.
  6. Close the Printer Ports window.
  7. Select the PDF1 checkbox, if it is not already.
  8. Click the Advanced tab.
  9. Select Spool print documents option.
  10. Clear the Enable advanced printing features checkbox.
  11. Select the Print directly to printer option.
  12. Click the Apply button. Click OK.
  13. Choose Windows Start and choose Run.
  14. In the Open field, enter %windir%. Click OK.
  15. Right-click the System32 folder and choose Properties.
  16. In the Properties window, click the Security tab.
  17. In the Group or user names list, select Users. In the Permissions for Users list in the Allow column, select Read, if not already selected, and select Write.
  18. Click the Apply button. To save the changes, click OK.
  19. Restart your computer.
  20. Note: For the changes to take effect, you must restart your computer.
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows Vista platform:
  1. Make sure that you are logged in as Windows Admin.
  2. Choose Windows Start > Printers.
  3. Right-click the QuickBooks PDF Converter icon and choose Properties.
  4. Click the Ports tab. Click the Add Port button.
  5. Select Local Port. Click the New Port button.
  6. For the new port name, enter PDF1. Click OK.
  7. Close the Printer Ports window.
  8. Select the PDF1 port checkbox, if it is not already.
  9. Click the Advanced tab.
  10. Select the Spool print documents option.
  11. Clear the Enable advanced printing features checkbox.
  12. Select the Print directly to printer option.
  13. Click the Apply button. Click OK.
  14. Restart your computer.
    • Note: For the changes to take effect, you must restart your computer.
  15. From QuickBooks, print, email, or create a PDF document.
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows 7 platform:
  2. Choose Windows Start > Devices and Printers.
  3. Right-click the QuickBooks PDF Converter icon and choose Printer Properties.
Hope that it will work for you,
Thanks,
She Morillo
Dec 04, 2012 | HP LaserJet 4700 Printer
Printing Backwards like a mirror image
You need to change the printer properties.
You can do this a few ways:
  • Click File , Print , then click the Properties button.
  • Click File , Print Setup , then click the Properties button.
  • Click File , Print , Setup , then click the Properties button.
  • Click Print , Properties , then click Printer Assistant .
  • Click the Taskbar Printer icon.
  • Right-click the applicable 3740 icon in the Printers folder, then click the Printer Preferences button.
Click on the "Basics" tab.
The 3rd option under "orientation" will say "mirror image".
Make sure this is un-checked.
Mar 24, 2008 | HP DeskJet 3740 InkJet Printer
191 people viewed this tip
David Payne
David Payne
