Tip & How-To about Televison & Video
Noise will randomly cut out Panasonic CT-2789VYD 27" TV
Its possible this could be resolve without taking the tv back. Make sure it's not the source. IE cable box, xbox or ps3 etc. Try swapping out wires. If all else fails, then one board should be the culprit. I believe (If my memory serves me correctly) the name of the board in the A-board. The input board. If its under warranty, then you may want to call for service.
Televison & Video Logo
how do I start watching Netflix on my hitachi smart TV
Open the Netflix app and sign in to your account!
Dec 24, 2016 | Netflix
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but it would not recognise a signal. after an hour of messing around i finally got a signal, but when i open the tray it disappeared and i could not get the signal to come back. ive researched on the net, i've tried the controller reset (y + RT) but nothing seems to work. i gave up, deciding to play xbox on crt with compontent cables. I put the hdmi back into the ps3 and now the ps3 wont show a signal. there is no manual switch on the xbox. If this is the result for hdmi i will not be buying an hdmi tv. Please, what is the solution?
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
My new sharp LC-52D65U tv continuously gives the sound display on the top right hand corner when it switches from mono to stereo etc. It dosn't do this all the time but for a while it will start again.
Make sure it isn't the source causing the problem. I.E. Cable box, dvd player, xbox or ps3. Try switching the wires. If all else fails, replace the main board.
Dec 05, 2009 | Sharp Televison & Video
Sound cuts out frequently for a few seconds
May 26, 2009 | Panasonic TH-50PX50U 50 in. Plasma HDTV
350 people viewed this tip
Top Televison & Video Experts
