Tip & How-To about Televison & Video
Just blue thin lines Flat Panel Televisions
First Try:
HI...
The HOT transistor ( Horizontal Output) has failed
Expect to pay about $100 to get it fixed ( If you bring it to a tech)
OR:
This is vertical problem. The tv have a cold solder in vertical ic or ic is bad.
Televison & Video Logo
the sound is great, but the picture has gone to gray with horizontal white lines across the screen. It is 20 years old, and probably not worth fixing, but i will ask anyway, just in case it is a simple fix.
Hello Sat, hi, its a failure of the horizontal output transistor responsible for high voltage. This transistor is needed to be replaced. you need a TV tech guy to have this fixed. have it checked first, the trouble is common to CRT type TV really easy to fix. for a tech guy.
Dec 07, 2010 | RCA Televison & Video
Sony Trinitron: No Picture
It is likely the HOT (horizontal output transistor) and a couple of associated capacitors.
common failure.
the HOT is around 8.00 and some for the caps.
but almost no tv person works for less than 100. and provides a warranty. so you can expect 150. at least for a bill.
Jan 27, 2008 | Sony KV-27V22 TV
sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV WILL NOT COME ON - TV Chirps when you plug it in
The F25432 uses the CTC203 series chassis. The most common cause of the picture being intermittent is poor solder joints on the small coil connected to the base of the horizontal output transistor. These cracked solder joints will eventually cause the horizontal output transistor to short, and the power supply will "squeel" when plugged in. If you have experience working on TV's then you can try resoldering the joints on that coil and checking/replacing the horizontal output transistor. If you do not have experience working on TV's then allow a qualified tech to handle it for you.
Aug 21, 2007 | RCA F25432 25" TV
442 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
