Tip & How-To about Computers & Internet
Webkey / Wireless Key
A webkey is a group of character, numbers and symbols used to access theinternet though a wireless router.
To find this out type in your router ip address into your web browser addressbar for example 192.168.1.0.
You will then be asked for a username and password, this depends on the routeryou have, a link below has some of them
Default passwords set by you ISP or routermanufacture can be found on the link below:
http://www.anameless.com/blog/default-passwords.html
Once you are on the router find the wireless setting and it will normally bedisplayed somewhere on that page. The webkey may also be classed as securityencryption code and found on the security tab.
You will not only be ableto view your webkey but also change it if needed.
Computers & Internet Logo
what is a webkey
A webkey is a group of character , numbers and symbols used to access the internet though a wireless router.
To find this out type in your router ip address into your web broeser address bar for example 192.168.1.0
You will then be asked for a username and password, this depends on the router you have, a link below has some of them
Once you are on the router find the wireless setting and it will normally be displayed somewhere on that page. The webkey may also be classed as security encryption code and found on the security tab.
May 08, 2011 | Nintendo DS Lite
ip adress of my router
Check IP Address from command prompt or DOS.
· press <windows key>+<R>
· type "cmd"
· press ok button. a black box will appear
· type "ipconfig /all" then press enter key
· locate wireless connection group by scrolling up/down. ip address should be listed in wireless connection group.
mongkey_21.jpg NOTE: ignore highlighted physical address.
I hope this works for you. Good Luck !
Mongkey
"Understanding explains better..."
Jan 27, 2011 | Linksys Wireless-G WRT54GS Router...
error code 51330?
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  4. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  5. Ensure that the router is set to broadcast in "mixed" or "b/g" mode. Routers set to "g only" may not be able to allow a successful connection from the Wii console. (The option to change this setting is typically found in the "Wireless" section of your router's settings. For information on accessing your router's settings, click here to select the brand name and model number of your router, if available.)
  6. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  7. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Oct 23, 2009 | Nintendo Wii Console
cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
2,643 people viewed this tip
David Payne
David Payne
