Tip & How-To about Computers & Internet
Find a Printer Driver on Windows 7
1. Go to control panel
2.Hardware and sound
3.Devices and printers
4.Add a Printer
5.Add a local Printer
6.Select the port or create a new port
7.Find your manufacture (Left Side)
8.Find your printer belonging to the manufacture (Left Side)
9. Click Next
10.Type in the printers name
11.Printer will now install
12.Select if you want to share your printer to anyone else on your network
13.Select if you want it as the default printer (The printer which will be used by default if you click quick print)
14.Finish
Computers & Internet Logo
fs-1118mfp not printing over the network
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Network printer win 7
If the driver is already available and you're getting the error "Windows cannot connect to the printer" and "Operation failed with error 0x0000000d" in the detail,
I found a solution from Vista that can be adjusted to work in Windows 7:
1. In "Devices and Printers" click "Add a Printer"
2. Select "Add a local printer"
3. Select "Create a new Port" and use "Local Port" as the Type
4. Enter the Network Path to the Printer (ie. \\ComputerName\SharedPrinterName) as the Port Name
5. Choose the printer from the list
6. Choose whether you want to use the driver that is currently installed or replace it
7. Name the printer
8. Choose whether to share the printer or not
9. Choose whether to set the printer as the default printer or not
Jan 07, 2010 | Kyocera FS-1118MFP Laser Printer
MacBook Pro will not recognize drivers for OKI C3200N
Sir,
Go to (Start > Control Panel > Hardware and Sound > Add a device) Check for connected devices. You can also go to (Start > Control Panel > Hardware and Sound > Add Printer > Local) check the USB1, 2, 3 options is available for using an existing port. The options are LPT1, 2, 3 (Printer Port) | COM1, 2, 3, 4 (Serial Port) | FILE (Print to File) | TPVM (Thin Print) | XPSPort. Select the appropriate port and try it…..
Thanks
good luck
Aug 07, 2009 | OKI C3200n Led Printer
unable to install DP G 301 For laser jet 5 printer
0.Follow the manual instructions to configure the Printer Server (tpc/ip), connection toyour local wireless LAN, etc. then, specific for Vista: 1.Vista Start Button 2.Control Panel 3.Printer 4.Add New Printer 5.Select Local Printer 6.Click on "Create new Local Port" and from the menu "Standard TCP/IP Port" 7.Click on "Next" button 8.Menu "Type" select TCP/IP and write the IP address of your Printer Server. UNSELECT "detect printer to..." then press "Next" button 9.If everithing is fine, it must find your printer server. 10.Select your driver ... that's it .... unfortunately I found some problems printing documents: it works till half page then the printer stop and I must cancel manually from the printer the job in order to reset the printer itself.... looking for solutions
Mar 16, 2009 | D-Link Computers & Internet
new comuter with windows vista and can not load printer hp photosmart 7660
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click the Windows icon, click Control Panel , click Hardware & Sounds , and then click Printers .
3. Click Add a printer .
4.Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select "Deskjet 5600"
9. In the Printer name text box, type the printer name, and then click Next . The printer driver starts to install.
10. After the computer displays a message that the printer was successfully added, connect the USB cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Now let's configure the driver
1. In the printer folder, right-click the name of the printer, and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to USB.
Now let's make a test
1.Click the General tab.
2. Click Print Test Page
Your printer should start printing in a few seconds.
Dec 02, 2008 | HP Office Equipment & Supplies
1,758 people viewed this tip
David Payne
David Payne
