Tip & How-To about Computers & Internet
Installing Windows XP (10 Easy Steps)
1. Install the windows disk.
2. Check your bios settings to make sure you have boot from CD drive selected
3.If you have boot from CD drive select, you will get a display which says "Boot disk press any key" . If this displays press enter.
4.Select the otipon you which, there is normally 3.
5.follow the onscreen instructions.
6.once it as installed you will need to remove the disk
7.follow windows xp instructions (Username, password, network settings ect..)
8.Select the display resolution
9.Windows is now working
10. Install any required drivers and updates.
Computers & Internet Logo
First boot of Win 7. New PC build
Hi.
First of all when you are in the BIOS and have set the DVD/CD drive as the first boot device make sure you save the settings before you restart the computer as it will not remember the changes if you don't.
Make sure that the lens on the CD/DVD drive is clean and also make sure the Windows 7 install disk is clean and free of any finger prints.
make sure that you keep tapping a key when the drive spins up as sometimes people miss the "Press any key to boot from CD/DVD" message.
If you still can't get the disk to boot then try the install disk in a working PC and see if that reads the disk. If it does then the optical drive could be faulty or does not support DVD format.
Regards.
2answers
when I restart my computer and after I enter my
Probably your system has been corrupted, or you have installed a software that caused your system not to function due to conflicts.
The solution that i find to solve your problem is to perform windows xp repair install, which will replace corrupted files on your system in order for you system to run properly.
Follow these step by step solution on how to perform the Windows XP Repair Install.
You should first check if you have these on your system.
1. A CD/DVD Drive.
2. A bootable Windows XP Install disk, depends on the version of your Windows XP , whether it be SP3 or SP2.
3.Idea on how to boot to your BIOS settings, you can check it using your systems manual or you should see a press button (e.g "Press F2 to SETUP").
Step by step solution on performing Windows XP Repair Install.
1. Insert the Windows XP installer on your CD/DVD Drive.
2. Restart your system.
3. Go to your BIOS Settings and set your CD/DVD drive boot priority. We will be booting to your Windows XP Install disk to perform reinstall on your system.
* Reinstalling doesnt affect your programs, but will just delete the previous windows xp system files and replace it with a new one.
4. When you are now in the Windows XP Install screen where you can select if you want to install windows xp, go to windows repair console or exit the installation. You should select "to Setup windows XP now press Enter".
Heres the screenshot as a guide.
Press Enter, then when you see Searching for previous windows installation, you should select "R" to repair your installation, if you dont see any "searching for previous windows installation message" then you should check your bios settings.
After the reboot, you should set back again your BIOS to boot from your hard drive. restart your system, also you should prepare a valid windows xp cd key for that because you will be needing it confirm the setup process of your system.
After the reinstallation process, you can now boot your windows xp system nice and clean. :)
Trying to install XP when disk selection comes up it reads, "Unkown disk. There is not disk in this drive". NOt sure what that means.
your drive is not being read,
have you set BIOS to boot from CD ROM,
is your CD ROM working,
is your XP CD working
Do the following
1 go to BIOS and re-set to BOOT from CD ROM
2 use another copy of XP/Win98/Vista etc to verify if CR ROM is reading the CDs else...
if you doubt CD ROM drive has a problem....
3 use a USB external CD ROM, and to do that u need to re-set the BIOS to boot from USB CD ROM
2answers
After installing new Biostar Motherboard (MCP6P-M2+), Windows XP won't start
You may need to check your bios settings and make sure the proper hard drive is set to be booted. If it is, follow the next set of instructions.
Windows " tailors " itself to the hardware it's connected to when installed. An easy fix is to repair your XP install like thus:
boot the PC from the XP installation disk
DO NOT select recovery console if prompted, instead continue installation
when XP searches your HDD it will find your previous install of XP, when it does, it will ask you if you wish to install, or repaire, select repaire...
it will seem as if XP is being re-installed, infact it is, but it will retain your files, and programs.
Once completed, your computer should boot properly.
Grand Canyon Tech
Grand Canyon Tech
