Tip & How-To about Loctite Corporation Glue Super Gel 14oz
How to increase Super Glue shelf life.
If you have noticed once you open a Super Glue tube it dries up with in a day or two and becomes useless.
Try placing the tube upright after wiping the nozzle and replacing the cap, in a refrigerator. This will extend the life of the glue at least by a few weeks.
Do not put it in the Freezer.
Loctite Corporation Glue Super Gel 14oz Logo
Rear view mirror
1. Slide the metal disc off the base of the rear view mirror assemble. For newer models of cars the metal plate may have to be removed with a properly sized Allen wrench. These are L shaped wrenches that are designed to remove hex head screws and can be purchased at any hardware store. While there you should also pick up a razor blade scraper and some masking tape.
2. Head to your local Schuck's or other automotive store and purchase a rear view mirror adhesive kit for around $3. This super strong adhesive is a two part system that comes with a tube of glue and a vial of accelerant.
3. From the outside of the car, use masking tape to mark the area where the old glue adhesive still remains.
4. From the inside, scrape off whatever is left of the glue residual.
5. Since this glue only works in temperatures of 60 or above, you will have to make special provisions when the weather is cold. The car should be placed in a warmed garage or facing the sunlight. A blow dryer can also be used to heat up the windshield, although don't hold it too close to avoid cracking the glass.
6. Once the glue has been scraped off the windshield, wipe down the area with rubbing alcohol. The metal plate should also be wiped down with alcohol.
7. Apply the accelerant directly to the mounting area on the windshield. Allow to let dry 5 minutes. In the meantime, apply the accelerant to the flat part of the base plate as well and let dry.
8. Slather on the adhesive on the back of base plate and press it onto the glass. Hold in place for about 2 minutes until the glue begins to set up. Let the glue dry overnight before reattaching the rear view mirror.
Jun 11, 2013 | Cars & Trucks
the leather edge on the sole of my Engineer boots is coming away.
Do you have a a pair of shoes that you bought not too long ago and the sole is coming apart? If you rather not risk buying another pair of the same shoes only to have them come apart, then this is the article for you.
Difficulty: Easy
Instructions Things You'll Need:
  • superglue
  • shoes to fix
1.
Get a tube of super glue--any brand name should do. Just the regular type should do, no need for any extra strength formulas or special types. Make sure the tube has been properly opened at this time--the seal on the tube has had a hole punched in it, in other words.
2.
Get the shoe(s) that need its/their sole(s) fixed. Where the sole is coming apart on the shoe, squirt in a good amount of super glue, but not too much that it will gush out. (If it does, try to wipe off the excess).
3.
Hold the sole and shoe together for the recommended drying time or until they seal. Try not to get any glue on your fingers at this time, as it can stick flesh to other objects.
4.
The sole should be fixed at this time. Sometimes it has to be done over if the drying time hasn't been followed or the glue might have some problem with it. Repeat this procedure for other shoes to be fixed
Dec 29, 2010 | Frye Clothing Accessories
Does any body know of a guide detailing how to repair a cracked screen in an HP Pavilion TX2000? The screen itself is okay, but the outside plastic-type layer is cracked.
try this:
use gorilla glue and make sure you clamp pieces in place near crack after it dries scrap off expanded glue with your fingernail...
or try super glue but pen wipe off excess glue quickly and clamp near crack
Nov 14, 2008 | HP Computers & Internet
super glue on the shutter
sometimes fingernail polish remover will remove... if you use that then let air dry for one hour before turning camera on
Aug 23, 2008 | Olympus FE-210 Digital Camera
printer problem Officejet K60
dry the section thats bad use a little super glue to apply both ends together after you open ink cartridge
you will get messy so i sugest old clothes newspaper and some disposable gloves once you have the ink ribbon glued back together let dry in fridge for about 4 days sinces its cold its going to take a little longer for glue to dry but wont dry out the rest of the ribbon
this is the only eldest way since typewriter days this has been the simple fix of printer ribbons
make sure to always keep back up ribbon so your work doesnt fall behind
Jun 01, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
777 people viewed this tip
Top Loctite Corporation Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Loctite Corporation Office Equipment and Supply Expert? Answer questions, earn points and help others
