Tip & How-To about Televison & Video
Disc won't load
The only troubleshooting you can try is to unplug the unit for 30 minutes. If the problem persists, the unit needs to be repaired. If you're under warranty, the manufacturer will repair or replace the unit. If you're out of warranty, they may have an out of warranty exchange or repair program.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Televison & Video Logo
I have a Mitsubishi Unisen TV - installed professionally with a stereo system. After watching TV for 30 minutes or so I get a message that new device has been found, recommend HDMI, I can't select anything, HDMI is not a choice, then screen goes blue and I have sound, but no picture. The company that installed it has been out 3 times, but problem continues and they don't have a clue, unless it's the TV
I'm sorry that the TV is not displaying any picture on the screen. Please follow the troubleshooting steps and check the operation:
  1. Please make sure that the connections are secure and proper.
  2. Try connecting a different video source like DVD player or VCR and check the operation. If it works with another device, the issue might be with the input device currently.
  3. Also try connecting the device to a different port in the Computer if no other devices are available.
  4. If the issue persists, try with a different cable.
  5. Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
  6. Please perform a system reset and check if that helps. Please follow the below steps to perform the system reset.
If the issue persists, after all above troubleshooting steps, service may be required. You can click hear to setup service for the TV. You may also contact Mitsubushi it is under warranty to get the free repair options.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 01, 2011 | Mitsubishi WD-60735 Projection Television
tv won't do any thing samsung 3 lights flashing and a ringing sound. It acts like it trying to reboot
The only troubleshooting you can try is to unplug the unit for 30 minutes. If the problem persists, the unit needs to be repaired. If you're under warranty, the manufacturer will repair or replace the unit. If you're out of warranty, they may have an out of warranty exchange or repair program. Contact the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 07, 2009 | Televison & Video
TV/DVD combo. will not read the DVD and ejects it.
Aug 04, 2009 | Televison & Video
dvd player won't load disk
Aug 04, 2009 | Daewoo DVD-5800 DVD Player
Pulstron dvx-2250:With inserted disk, it shows ''NO DISK'' and will not play
The only troubleshooting you can try is to unplug the unit for 30 minutes. If the problem persists, the unit needs to be repaired. If you're under warranty, the manufacturer will repair or replace the unit. If you're out of warranty, they may have an out of warranty exchange or repair program. Call the manufacturer for your full range of options.
390 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
