Tip & How-To about Starbucks Saeco Italia Digital Barista Coffee Machine
My Italia, Classic, Palazzo, has a slow drip into my cup (Brewing)
If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head.
If it run normally, your grind is to fine. Turn the grinder knob to a larger number. It takes 3 times to change to the new grind.
If it still dribbles, remove the brew unit (behind the door)
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door with a rubber tip. 2 or 3 screws hold it to the top. Remove the screws while holding the manifold. Once they are removed, lift the l assembly off (becareful, there is a spring and inside a steel ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the steel ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.....
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
Now use air to blow back through the opening where the steel ball was to clear the opening. Once its open, clean then reassemble. Brew unit on towel right side up. Drop the steel ball in first. Then the spring.
Then place the manifold on top of that with the pipe towards the door. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this.
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
On my Saeco Digitale Royal Plus on the Display coms Ventilate and is doing noting no coffe its coming and i can do the water
Hi If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head. If it run normally, your grind is to fine. Push the grinder lever to a larger number. It takes 3 times to change to the new grind. If it still dribbles, remove the brew unit (behind the door) Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the backside towards the machine (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (becareful, there is an O-ring, spring and inside a crystal ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the crystal ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out. Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers..... Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side. With the brew unit upside down over the towel insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side. Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ba Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this.
Jun 27, 2011 | Saeco Royal Digital Plus Coffee...
the machine goes through the motions, takes ages, but no coffee comes outchristyler@eircom.net
Holding the handle, on the top left side is the brew head, there is an outlet pipe(rubber cup) that exits the front side towards the door. 2 screws hold it to the top. Remove the 2 screws while holding the manifold. Once they are removed, lift the l assembly off (becareful, there is a spring and inside a steel ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the steel ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Jan 13, 2011 | Gaggia Titanium Espresso Machine
I have a Gaggia Titanium. It has stooped making coffee. It brews and grinds but no coffee comes out. If I open the steam know coffee colored water comes out. No water comes oiut when I rinse it. I have cleaned the machine thoroughly.
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door. 2 screws hold it to the top. Remove the 2 screws while holding the manifold. Once they are removed, lift the l assembly off (becareful, there is a spring and inside a steel ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the steel ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Jan 02, 2011 | Gaggia Titanium Espresso Machine
I have a Gaggia Titanium that's stopped working. The coffee will brew and grounds. But no coffee comes out. If I open the steam knob coffee coloured water comes out. I've the the brew unit. Also if I try to rinse, water only comes out of the steam knob.
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the frontside towards the door. 2 screws (some have 3) hold it to the top. Remove the 2 screws while holding the manifold. Once they are removed, lift the l assembly off (becareful, there is a spring and inside a steel ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the steel ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Saeco Majic - My machine is very slow and drips the coffee. What do I do?
If you make a pre-ground shot but don’t put any coffee in it, and it does the same thing you have a blockage in the brew head.
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the backside towards the machine (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (becareful, there is an O-ring, spring and inside a crystal ball (don’t loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the crystal ball should fall out. If it doesn’t come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON’T use the key to install the screen, use your fingers.....
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Jul 26, 2010 | Saeco Magic De Luxe Espresso Machine
794 people viewed this tip
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
