Tip & How-To about Simmons Outdoor Blazer Matte (4 x 32mm) Telescope
Simmons 3*9 22 MAG scope
I bought one SIMMONS 3*9 MAG 22 riffle scope from USA last month in $54 and fixed it on my .22 riffle with proper instruction. When I shooted 2-3 bullets, its + sign is moved from actual target.
I made the target and + again in sync and after shooting 3-4 bullets, its + changed the position. After consulting with some mechanic, he told me the SIMMONS telescope is manufactured in China and its acuracy is not upto the mark. He was advocating me to buy bushnell scope for my riffle.
Now I am confused and not able to identify how to fix this + movement problem in my scope.
Can anyone please help me on this ????
Your reply is very much anticipated.
Thanks !!
Simmons Outdoor Blazer Matte (4 x 32mm) Telescope Logo
loss of focus when izoom in
This typically means that you are have exceeded the scopes ability to focus at the distance that you are shooting. This scope is optimized for 50 yards and will function well at all magnification settings. Closer than this optimal distance the higher magnifications may present problems with blurring. Many scopes have a "parallax" adjustment that changes the optical focus to correct this problem. Several of my 22 mag scopes have this adjustment on the objective bell. You simply set the indicator line on the appropriate yardage indicator (making minor adjustments to fine tune focus). Hope this helps
Sep 16, 2010 | Simmons 22 Mag 39X32 with Rings
How do I adjust the reticle for a Simmons Mag 4X32 scope. The reticle is not straight up and down and level parallel.
the reticle should be level if its not you need to turn the scope body round in its mounts till it is level and then nip the scope caps up
Sep 06, 2010 | Simmons 511070 4x32 22 MAG Riflescope -...
the elevation adjustment screw will not turn on a simmons 22 MAG mini 4x28. Which way should it turn to raise point of impact? Counterclockwise or Clockwise?
all scopes are marked for up or down with a " u or d" or a
"+ or -" for up and down
just dont forse the turret screws or you will bust the scope
Aug 22, 2010 | Simmons 511070 4x32 22 MAG Riflescope -...
328 people viewed this tip
Top Simmons Outdoor Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Simmons Outdoor Optic Expert? Answer questions, earn points and help others
