Tip & How-To about Apple iPhone Smartphone
How to Enable CAPS on a iOS device (iPhone, iPad, iPod Touch)
When in a app with a keyboard up triple tap on the up arrow that is on the left side of the keyboard, you'll notice it turn a solid color. You are now in caps lock mode!
Apple iPhone Smartphone Logo
Why won't my Iphone 5 wont turn sideways
This is because you've got the screen rotation lock on
To turn it on or off, do the following:
  1. In iOS 7 or higher, swipe up from the bottom of the screen to reveal Control center. (In iOS 6 or lower, double tap the home button on the front of the iPhone or iPod touch. This will reveal the fast app switcher row of apps at the bottom of the screen)
  2. In iOS 7, tap the lock-and-curved-arrow icon. If it is white, it's on; black and it's off
  3. In iOS 6 or earlier, swipe left to right to reveal the Music app, music player controls, and on the far left, an app with a curved arrow in it (if the lock is turned on, you'll see the lock inside the arrow)
  4. To turn screen rotation lock on, tap the curved arrow icon so that the lock appears
  5. To turn screen rotation lock off, tap the icon so that the lock disappears
  6. When you're done in either version of the iOS, single tap the home button and you'll be returned to normal operation of your device.
Jun 21, 2014 | Apple iPhone Smartphone
If I reset my iPhone to factory settings will I lose any of my data, such as music,photos,aps, and other data stored on my iPhone. Since I upgraded my iPhone, I have lost the sound for the ringer and the clicks for my key board and other other alerts
On the Reset screen, you'll have a number of options for deleting iPhone data and settings.
Reset All Settings - This deletes all of your preference settings, returning them to the defaults. It will not erase any of your data or apps.
Erase All Content and Settings - If you want to fully delete your iPhone, this is the option to choose. When you tap this, you'll not only erase all of your preferences, you'll also delete all music, movies, apps, and other data from your phone.
Reset Network Settings - To return your wireless network settings to their factory default states, tap this.
Reset Keyboard Dictionary - Want to remove all the custom words and spellings you've added to your phone's dictionary/spellchecker? Tap this option.
Reset Home Screen Layout - To undo all of the folders and app arrangements you may have created and return your iPhone's layout to its default state, tap this.
Reset Location Warnings - Each app that uses the iPhone's GPS to be location aware asks your permission to use your location. To reset all of those warnings to their default off state, select this.
Mar 31, 2012 | iPhone Apps
I got a memory card card reader that fits in myu tower it conects to the front usb pins but i dont know which way around the connector needs to be
David, first take a look at the connector at the end of the card reader's cable. It should be a rather wide rectangle, silver in color. You'll notice that one of the two wide sides has a thin line in the metal (or a ****, or whatever one might call it). That side should generally face down when you connect the cable to your PC.
If the USB connections are on the back of your PC and are vertically oriented, it's slightly trickier. You'll probably notice that the USB "ports", as well as all the other cable connections, are all grouped together in a rectangular area, with many of the connections being colored. That rectangular area is probably flush with one or the other side of the tower. While looking at the back side of the tower, the side that rectangular connector area is closer to is considered the "bottom direction". So if it were, say, on the left side, turn the USB connection so that the side with the **** is on the left as you connect it to the PC.
If you're unlucky enough to have a USB connector at the end of the cable on which both of the wider sides look 100% identical (without that distinguishing ****), then another way to figure it out is to look into the inside of the connector. You'll notice that it's partly hollow, and the other half is taken up by a white, black or possibly blue piece of plastic. Turn the connector so that that plastic part is in the lower half
Aug 08, 2011 | Computers & Internet
Can't find list of recent downloads
To view downloaded and installed apps from HTC Inspire 4G:
1). From the Home screen, tap the lower left button (with an icon of an "arrow up") . 2. Press MENU, and then tap Share. You'll then see the list of games and apps that you downloaded and installed from Android Market.
Jun 27, 2011 | HTC Inspire 4G Smartphone
side key functions on HP#5189 keyboard
Left side keys - moon-hibernating mode, club+hp - takes you to hp internet club (lots of resources,free classes, etc on hp), globe spinning-takes you to internet-yourhomepage, envelope-takes you to windows email, magnifying glass- takes you to windows live search, ?-takes you to help
right side keys- arrowup1-opens disk drive, arrow up 2-opens 2nd disk drive if you have two, solid dot-opens dvd suite, arrows left-rewind, arrow right -fast forward slow, 2 arrows right-fast forward fast, and solid square -pause these are all media functions
I discovered all of this by taking a chance and pushing the key to see what happened. really wish they put a manual, or screen showing functions for the keyboard. hope this helps someone else!
Mar 26, 2009 | HP Computers & Internet
1,171 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
