Tip & How-To about Computers & Internet
Tips to clean and speed up your computer.
If you wish to speed up your computer or just give it a good cleaning, you have come to the right place! Follow the tips below and your computer should perform better.
CCleaner is a program I have used for years, and it is an amazing tool. It offers the ability for you to clean out old temporary files, browser cookies, remove unwanted programs, fix registry errors, disable start up programs and even manage system restore points.
Click here to download the program
-Install and open up CCleaner. On the left, you will notice 4 options. The first(top option) is cleaner. We will make sure we are on this tab and click the "analyze" button near the bottom middle. Let the program analyze and once it is done click the "run cleaner option"
*Editing registry information can potentially be dangerous and I always advise to backup the registry before deleting anything from it*
When you install and remove programs, you can leave behind junk that over time can cause problems for your computer. We will clean up the registry now.
-Next, we will run the Registry analysis to see if anything can be fixed. Click on the registry tab on the left of CCleaner and then click the "Scan for issues" button. Once this is done, go ahead and click the "Fix selected Issues" button.
Over time, your computer can accumulate many programs that will start up when windows reboots causing the reboot process to be extremely slow. Some of these programs are non essential and can be disabled from start up. The next step we will disable any unwanted start up programs.
*Disabling essential programs from start up may cause computer issues. Only disable programs that are not needed to be running when the computer starts up. Some examples are Itunes, Windows Media Player, Adobe update*
-Click on the "tools" option on the left of CCleaner. Then click on the startup tab. Expand the CCleaner window to maximize so you get a good view. You do this by clicking the box icon at the top right of CCleaner. In the middle window, CCleaner will list all programs that will start when your computer is turned on. You can go through each program and disable any that you see fit. I gave some examples above of programs you can disable. This can increase your start up time!
Now we can close CCleaner.
-In this step we will run the built in Windows disk cleaner and disk defragmenter to finish our clean up job. In windows 7 you can access these tools by going to Start and in the search box type Disk. The two top options should be Disk Cleaner and Disk Defrag.
Click on Disk cleanup and a program will run, and calculate files to be deleted and how much space you can save. CCleaner will have already cleaned up much of this junk but go ahead and select the options you wish to remove and click the OK button.
Next, run the Disk defrag tool. This tool will show you if your disk is badly fragmented and if so, run the program. It is best to do this overnight while you are sleeping as it can take up computer resources.
Other Tips
A new tool I have started to use is TuneUp Utilities. The 2011 version is very good and is easy to use. You can download it by clicking here. You can use it to basically do anything from disabling start up programs, defragging your hard drive, changing Windows settings and even changing your Windows Login screen. It will guide you through optimizing your computer.
Okay, your computer should be all clean and run a bit faster now. I hope you enjoyed this Tip!
Regards,
G33k
Keywords
Computer speed up, cleaning computer, clean computer, speed up computer, optimize computer, free computer software tools, free computer cleaning tools, free cleaning tools, free computer software, how to clean computer, how to speed up windows, how to clean laptop
Computers & Internet Logo
slow internet download speed
Run a virus and malware scan if not infected your ISP is the problem
Oct 26, 2013 | Computers & Internet
internet is really slow
A slow Internet connection could be caused by any number of reasons. It may be connection or traffic problem.
To increase your Internet speed you can follow these tips give below:
1. contact our ISP and get a latest speed plan from them. It's better way to increase our speed.
2. clear cookies from our browser
3. Delete unwanted files.
4. PC Optimization:
It is important to clean your PC regularly. It means a normal maintenance tasks such as, cleaning the disks, registry repairs and Disk Derangement
5. Reduce our bandwidth overhead
6 Scan With Latest Antivirus Program
7. Use Updated Web Browser
8.Install Anti virus software.
9.Consult with your Internet service provider to ensure that your modem is configured correctly.
10.If you are using a DSL connection over your landline, make sure that you have high-quality filters in place to get optimum signal speed.
After, completing this steps, you can check our internet speed from this site ScanMySpeed.com
Oct 07, 2013 | Sony Audio Players & Recorders
my laptop computer is running slow? how can get rid of junks stuff on the laptop?
Your friend is a program called CCleaner. Run it, rerun it, do whatever you need. It's heavenly.
http://download.cnet.com/ccleaner/
May 24, 2011 | Computers & Internet
My Laptop is suddenly taking 15 minutes to load up after turning
clean the pc up to speed it up a little, download ccleaner and install it, run the cleaner and delete all the files it finds, then clean the registry and fix the issues found, if it asks you to save the changes to the registry click yes and fix do this a couple of times so no issues are found.
If the pc is still slow after this clean then the issue is either memory or the operating system is degrading.
http://www.filehippo.com/download_ccleaner/
good luck
Jan 26, 2009 | Acer Aspire 5100 Notebook
1,723 people viewed this tip
David Payne
David Payne
