Tip & How-To about Health & Beauty
VSI joystick constantly flashing
You may have mistakenly locked your joystick. Here is a tip on how to lock and unlock it.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
Health & Beauty Logo
unlock the controller
Locking/Unlocking the VSI
lock your powericon1.png chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speedicon1.png/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
Mar 16, 2014 | Pride Mobility Products Jazzy 1170 XL Plus
when i push power button on lights blink constantly, wont move
For future reference, here is the is a procedure for
To lock the VSI:
To unlock the VSI:
Mar 16, 2014 | NRS Hoveround MPV 5 - Used Power...
forgot how to unlock power chair
This is the procedure to unlock the controller on a Pride Jazzy:
lock your power chair to prevent unauthorized use.
To lock the VSI:
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
Jun 30, 2012 | Pride Jazzy Select 6 Indoor Power...
speed lights flash and machine will not run
Hi patriped,
Sometimes we lock our joystick by mistake.
Here is how to unlock it.
If this dosen't fix the problem you may have a bad joystick. Write me back for more info if thats the case.
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Jan 27, 2011 | Pride Jazzy 1113 ATS Indoor Power...
control flashing to light
unauthorized use.
To lock the VSI:
To unlock the VSI:
Try this. If it is not locked write back with more info.
mimobility
Jan 12, 2011 | Pride Jazzy Select 6 Indoor Power...
1,579 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
