Tip & How-To about Cell Phones
Change Your bootlogo After Jailbreak with Greenpois0n
These are instructions on how to edit or remove the boot logo animation installed
by running the jailbreak Greenpois0n
Cell Phones Logo
When I download song or movie meg. Was display on my IPhone 4 safari can not download this file n I can not download anther browser . So help me to solve safari problem n easy to download all file. I buy from third party so give me beat ans. & best site to easy download. Thank you.
By default, Safari does not allow you to download files to your device, this is the same for other browsers. One solution is to jailbreak your iPhone 4, and then install Safari Download Manager from the Cydia store.
To jailbreak your iPhone:
  1. Ensure you are running firmware 4.2.1 or above (Settings>General>About)
  2. If not, then launch iTunes, click on your phone, and update the firmware.
  3. Download Greenpois0n from: http://greenpois0n.com/ (download links are on the right hand side)
  4. Extract and run the Greenpois0n.exe and follow the instruction very carefully.
  5. After your device has been jailbroken, open Cydia, and search for "Safari Download Manager"
  6. Pay the required amount and proceed with your download, it should automatically set up.
  7. Restart your phone to be safe, and you should now be able to download any file.
Jun 28, 2011 | Apple iPhone Smartphone
i cannot open my iphone 4 and its stuck. there is a apple drawing with bone in the screen
One solution here is to force reboot your iPhone. To do that, simply press & hold the POWER & HOME buttons together for around 3 to 5 seconds or until the logo appears again.
If in case the logo appears but it still won't go through, the best solution is to re-do the jailbreak, which in your case I assume is by using greenpois0n.
If you are familiar in using this jailbreak tool (greenpois0n), download it by using the links below then re-do the jailbreak to fix your iPhone 4. If you're not at all familiar with this, you may read the step-by-step guide on using greenpois0n right here on FixYa. CLICK HERE to read the guide.
May 16, 2011 | Apple iPhone 4 Black Smartphone
need to unlock ipod
I guess you need a jailbreak tool. There are some methods you can use.
first:
open your ipod and go to www.jailbreak.me there you will be provided with necessary steps to unlock your ipod.
If your ipod is not compatible for use of jailbreak.me then you will have to download a jailbreak tools from http://greenpois0n.com/ after downloading greenpois0n follow the steps.
Mar 07, 2011 | Apple iPod touch
How to JAILBREAK iOS 4.2.1 on iPhone 4
Before you jailbreak your device perform the following steps:
1. Back up your iPhone with itunes
2. Download TinyUmbrellaGo.
a. Go to TinyUmbrella here: http://thefirmwareumbrella.blogspot.com/
b. You will download the version for your system, either OSX for Mac useres, or the WIN
version for Windows users. Look for this box for your download:
c. Plug in your iphone and open TinyUmbrella until it is recognized. The program will guide you
through the process. Basically, you will click a button to "save shsh" and the program does
the work for you.
***This TinyUmbrella stage is important to back up your SHSH blobs possible for future
jailbreaks, but more importantly TU has an important feature if your iPhone is ever "stuck" in
recovery mode. There is a "kick out of recovery" button that has saved me before.***
3. Go to http://www.greenpois0n.com/ and download the software for your operating system for the
Greenpois0n jailbreaking tool for iPhones with 4.2.1
4. After the software is installed, click on the Greenpois0n icon to run the program. It should look like this:
5. The screen will instruct you to power off your device, and then connect it to the computer with
a usb cable.
6. Press the "prepare to jailbreak (DFU)" button. At this point the screen on your computer will guide you through a series of steps of pressing the home (circle button at the bottom of your phone) and sleep (the button on top of your phone) buttons. If you don't follow the sequence properly, don't worry, it gives you the option to try again and again if needed. The sequence is:
*Press and hold the sleep button for 2 seconds.
*Continue holding sleep and press and hold home for 10 seconds.
*Release sleep button and continue holding home for 15 seconds.
You don't need to memorize this because the instructions will be on the screen with a countdown timer to help you out!
7. Once you've successfully entered DFU mode, the jailbreaking begins. It takes some time and there will be some tiny writing and scrolling on your iPhone screen. Just let it do it's work.
8. When it has finished with this, your device reboot and have a greenpois0n animation instead of the apple that you're accustomed to seeing. You're now jailbroken! There will be a new icon on your home page called "loader." Open this and it will tell you how to install Cydia, which is the jailbroken app store. Install Cydia, reboot, and have fun!
Dec 19, 2010 | Apple iPhone Smartphone
207 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
