Tip & How-To about Computers & Internet
How to configure a wired/wireless home network
In this guide I will go over the steps needed to setup a basic home network. In this network, we will have a desktop computer, a wireless laptop, printer, router and cable modem.
*All devices should be turned off at this point*
1) The cable modem which is usually provided by your internet service provider, should be connected to your coaxial cable(broadband internet) that is active, and can be anywhere in your household. This modem can also be for DSL connections(phone line).
*If you only have one device you wish to connect to your home network, this device can plug directly into the modem and you will not need a router*
2) Next, you will need to connect the router to the modem. You will use a Cat5 cable to do this. It is also commonly referred to as a Ethernet cable or patch cable. On the modem, you will see a Ethernet port, plug one end of the cable to this port. On the router, you will see many Ethernet ports. The port you wish to use to connect the modem to the router is usually separated from the other ports and may be labeled (modem or internet). The ports labeled 1-6 for example are your LAN ports and normally for computers etc. So, plug the other end of the Ethernet cable into the port labeled modem or internet that is away from the other ports.
3) Now, for each device you wish to have wired network access(computers, laptops, game consoles) you will need to plug an Ethernet cord into each one, and plug the other end into one of the LAN ports on your router.
4) Power on the cable modem, wait 30 seconds then power on the router.
4) Next, you will need to power on your desktop in order to configure the router. Please consult your routers manual in order to do so.
5) Once your router is configured, you should be able to access it from any of your devices and these devices should have access to the internet. If you wish to have wireless access also, you will need to setup wireless security, password and a SSID. Your SSID is the name you give the router, and this is the name that will show up when you search for routers within range of your computer. Below is a picture of a list of wireless access point SSID.
6) At this point there are several ways to connect a printer. For simplicity, you can connect it to one of the computers, and give access to the other computers. The following guide will go over this step,
http://windows.microsoft.com/en-US/windows7/Install-a-printer
I hope this guide helps you in your quest to setup a basic home network. There are many factors that come into play and additional steps may need to be taking but this will get you started!
Regards,
G33k
Computers & Internet Logo
why does belkin router blocks netflix ?
After you connect your router to your computer via an ethernet cable, enter the router's home page by entering 192.168.1.1 on a browser. Once there, look for DNS and enter the open google dns numbers.
May 29, 2014 | Belkin Basic Wireless Router
belkin n300db range extender setup problems
we will give you full guidance how to install Netgear N300 wireless.
There are following steps
Step1: Unplug the power to turn off your modem
Step2: Connect one end of the yellow Ethernet cable to your modem and the other end to the internet port on your router.
Step3: Plugin, then turn on your modem
Wait approximately 2 minutes, if your modem has a battery backup, first remove and reinsert the battery before connecting your modem to power.
Step 4: Connect the power adapter to the router, then plug it into an outlet. Wait until the wireless LED turns solid green.
Step5: Connect the router to your computer
To know more information
How To Setup Belkin Range Extender TechVaidya
Sep 07, 2012 | Belkin N Wireless Modem-Router F5D8633au4A
How can I set-up my Lexmark printer wirelessly? I seem to have loss my manual. Help!!!!
Wireless networking your printer or scanner may sound difficult, but newer machines are making it easier to do.
The first step is to get your home wireless network configured properly. Bradley Mitchell, the About.com Guide to Computer Networking, has a fantastic and easy-to-follow primer on networking that's a great place to start.
Microsoft also offers a handy tutorial on wireless-networking basics that will help if you're using Windows. If you're using Vista and running into problems, troubleshooting guide will help.
If you're using Windows 7 and want to share a printer on a home network, follow the links at How to Share a Printer on a Home Network with Windows 7.
Next, learn more about the basics of wireless printing with a primer from Etan Horowitz of the Orlando Sentinel.
If you're trying to use a scanner that doesn't have a network card, you can find some useful software from Remote Scan.
May 28, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I have 2 computers - a desktop without wireless and a new laptop with wireless. I want to connect the Belkin N150 basic wireless router to both these computers. I have introduced a "wired" connection to the desktop via the Belkin router (by running the set up CD) and am now trying to do the same to the lap-top via wireless but not am able to succeed. It makes a connection but cannot connect to the internet.
WIRELESS SECURITY ISSUES
UNINSTALL THE BELKIN ROUTER MANAGER FROM THE LAPTOP
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP ( WPA WILL NOT WORK )
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 21, 2010 | Belkin Basic Wireless Router
1,410 people viewed this tip
David Payne
David Payne
