Tip & How-To about HTC Wildfire Cell Phone
How and where to get the HTC Wildfire User's Manual?
As an HTC user myself, we're quite surprised with what this baby can do for us. May it be a task organizer that works like a virtual secretary, socializing, and even work and play at the same time. As a certified android user, I'm very very much satisfied with the performance of it(but not for gaming though) and will recommend it to a first time HTC/android user. I know that there are time that we tend to forget some things on our phone.It's not that we don't know how to use it, it's just we forget where these apps or settings are placed. That's why from time to time we may need to look into the user's manual. And I'm proud to say that HTC took some time in making sure that it will be easy for entry to intermediate users.
Here's the actual PDF (needs Adobe Acrobat reader to run) file: http://member.america.htc.com/download/web_materials/Manual/HTC_Wildfire/100518_Buzz_HTC_WWE_UM.pdf
Click on the link above to download the pdf file
For other languages, you can check this link: http://www.htc.com/www/userguide.aspx?p_id=316
Hope this simple tip can make your life easier. HTC wise :)
HTC Wildfire Cell Phone Logo
What is the link between gramsabha and gram panchayat?
The Gram Sabha is a meeting of all adults who live in the area covered by the Panchayat. Anyone living in the area, who is an adult, that is 18 years old or more, is a member of Gram Sabha. The Gram Panchayat has a Secretary who is appointed by the government. The Secretary is responsible for calling the meeting of the Gram Sabha and Gram Panchayat and keeping a record of the proceedings.
The main task of Gram Panchayat is to implement the development programmes for the villages that come under it. Gram Sabha is the place where all plans for work of Gram Panchayat are placed before the people.
Ajay Chandrakar Politician of Chhattisgarh Ajay Chandrakar
Mar 29, 2016 | Office Equipment & Supplies
Natures purest swing won't swing
I have the same problem. Works fine then next time I go to use it it won't work.
Feb 21, 2013 | Summer Infant 66010 Nature s Purest...
Yamaha Electone HS-4 doesn't remember settings
checked the internet and it states in the manual that if you do not use the organ for long time the user memory will be lost but the factory memeory will not be affected. check the below link:-
http://archive.org/stream/YamahaElectoneHsUsersGuide/YamahaHsUsersGuide_djvu.txt
Aug 30, 2012 | Music
my x-box tells me to open port to connect, i cant get it to work. bungie net tells me to open port 802.11 n not b or g . i cant make it work,x-box tells me my nat is not open. please help. thanks paul
The Linksys router, like any other router, will block "unsolicited" traffic from the Internet coming "into" the router (for "forwarding" to your computer that is "behind" the router).
So, you need to access the web-server "inside" the router, from a computer that is "behind" the router, and you need to modify the "blocking" of the router's "firewall", to "allow" (instead of "block") traffic from the Internet to a specific port-number.
You'll also need to "forward" that port-number to a specific computer "behind" the router.
Compare to a secretary that receives telephone-calls for several managers in the office.
When somebody calls the office, the secretary may look at the caller-ID, and may choose
to *NOT* pickup the telephone, i.e., to "block" the incoming call. Thus, none of the telephones
on the desks of the managers will ring -- they will not receive any notification that the secretary
has "blocked" the call. Or, the secretary may recognize the caller-ID as being that of the spouse of one of the managers, and may just "forward" that incoming call to the correct manager.
The secretary needs to know which of the telephones is associated with the spouse of the caller, so that the "correct" person responds to the incoming call.
The secretary is doing the 'NAT' ("Network Address Translation") to correctly do the "forwarding".
Similarly, the router needs to be configured to do the 'NAT' correctly.
Jul 13, 2011 | Linksys Computers & Internet
2,075 people viewed this tip
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
