Tip & How-To about Computers & Internet
6 Free Solutions is Behind You for Windows Password Recvoery
When you forgot your Windows login password, what would you do? Take your computer to a PC repair shop or buy an expensive Windows password recovery tool? Well, sometimes it costs you no penny to get back or reset your lost Windows password actually. Don't believe it? Just have a try of the following free Windows password recovery solutions if you forgot Windows password to your computer.
1. Ophcrack LiveCDMany free Windows password recovery tool are supposed to help you get back in computer if one forgot Windows password for your computer. In reality, some users resort to free Windows password recovery tool to unlock their PC, like Ophcrack. Ophcrack LiveCD is a completely self contained, bootable version of Ophcrack. Ophcrack LiveCD is the easiest and most effective Windows password recovery freeware that I've ever found to "crack" your forgotten Windows password.
Since you can't login your Windows PC because you lost the password, so first you'll need to visit Ophcrack's website to download ophcrack LiveCD. Please make sure that if you've forgotten Windows 7 password or Vista password, click on ophcrack Vista LiveCD. If you've forgotten XP password, click on ophcrack XP LiveCD.
2. Cain & AbelUnlike Ophcrack and other popular Windows password recovery programs, Cain & Abel requires access to Windows under an administrator account. In fact, Cain & Abel is a bit more complicated to use than other password recovery tools which is usually unavailable for Windows Vista as is said.
If you have no way of getting in to your Windows PC, you will not be able to use Cain & Abel to recover your password. Moreover, before you can use Cain & Abel, you'll need to download a rainbow table. These large databases of passwords are required so Cain & Abel can reset the forgotten windows password.
3. Available Admin AccountIt's well known that Windows administrator users have rights to change password of other user account on the same computer. So if you forgot password of the user account, just enter your administrator account and do as follows:
  • 1. Press F8 to enter the Advanced Boot Options when booting your PC.
  • 2. Select Safe Mode and enter your computer with an Administrator password.
  • 3. In Safe Mode, click Start-> Run-> Type control userpasswords2->click OK.
  • 4. On the coming up Users screen, click the name of the user account that you want to reset the password for, and then click Reset Password to process.
4. Windows Password Reset DiskIt is considered the easiest way to reset Windows password when you are forbiddened to access your laptop with protected password. However, many of us haven't enough consciousness on creating a Windows password reset disk before they lost the password.
  • 1. Type a wrong password on the Windows logon screen.
  • 2. Click OK when Windows displays a message that the password is incorrect and "Reset password" link will appear.
  • 3. Click Reset password to pop up Password Reset Wizard screen, and then click Next.
  • 4. Follow the steps in the Password Reset Wizard to create a new password.
Note:This solution takes effect provided you have created a Windows password reset disk for your Windows account in advance.
5. Typing Ctrl + Alt + Del (Only Under Windows XP)This option is only for Windows XP. Furthermore, the default administrator account on Windows XP is enabled and not password protected by default, which is disabled by default on Windows 7 and Vista.
  • 1. Turn on your Windows XP machine and go to its logon screen.
  • 2. Press Ctrl+ Alt +Del twice to pop up the classic logon box.
  • 3. Enter Administrator in the User name box and then click OK to log on your Windows XP machine.
  • 4. Click Start button to pop up the Run box, and then type control userpasswords2 and click OK.
  • 5. On the coming screen, click the name of the user account that you want to reset the password for, and then click Reset Password for password recovery.
6. System Recovery OptionYou can use system recovery options to reset lost Windows password by using Windows installation disc or access to the recovery options provided by your computer manufacturer. Also you can create a system repair disc as below:
  • 1. Click the Start -> Control Panel -> System and Security -> Backup and Restore.
  • 2. Click Create a system repair disc on the left pane.
  • 3. Insert a blank CD/ DVD into your CD/DVD drive and click on the Create disc button. It will start creating the System Repair Disc.
  • 4. When it's finished, click the Close button, and then click OK to finish.
Of course, if you cannot resolve your problem with these free Windows password recovery tools, you can create a password reset disk with Windows Password Unlocker, which allows to burn a password reset CD/DVD or USB flash drive to bypass lost password on Windows 7/Vista/XP/2000/2003/2008 in a short time.
Computers & Internet Logo
forgot windows login password
If you means you forgot windows xp password, you can use Windows Password Recovery Tool.It is a good tool for anyone who lost windows password. It can recover windows login password in few steps.
Oct 04, 2012 | HP Compaq nc8430 (RS431US) PC Notebook
I cannot use my DELL Laptop because I forgot my password.
Hi, once you forgot your password and for no reason to recall it. Just press cntrl-alt-del keys simultaneously and log in using username=administrator and password is none. The default username of your computer if not altered is administrator. Once you successfully logged in you can edit your forgotten password in users properties.
Jun 21, 2011 | Dell Vostro 1500 Notebook
how can i open vious lock
Forgot windows 7 password?If you could use another computer which could download from Internet, you can create a windows password recovery disk to reset windows 7 password. Third party windows password recovery software windows login recovery could create such a disk. Only four steps:
Step 1: Download Windows Login Recovery and install it on the available computer
Step 2: Run the software and use it to burn a Windows password recovery disk (you could burn the file into the blank CD/DVD or USB flash drive)
Step 3: Change the BIOS setting of your locked computer to make it boot from the CD-ROM (Start computer and press F2 or Delete to enter BISO setup)
Step 4: Boot your locked computer from the created disk and remove the Windows password
It is easy and safe. Hope to help you.
May 24, 2010 | Acer Aspire 4520-5141 Notebook
I forgot my Password to the Login of my Laptop
Have your HP laptop login password forgotten? Do you have another administrator? Have you created Windows password reset disk on your HP computer when it is available? Or whether you have installation CD?
If you have administrator, just change HP login account to this administrator and access HP computer with it. At this time, no matter which account, you can easily change or remove its password on Control Panel.
If you have password reset disk, on Windows login screen after you type incorrect password, there will be a message "Reset Password" prompting you to reset forgotten Windows password with reset disk. Just follow password reset wizard to do.
If you have installation CD, it will help you to restore HP computer or repair computer. But it is still dangerous for us to use it because it will delete some important data on your computer.
In consideration of data safe on computer, Windows Password Genius provides a safe Windows password reset environment WinPE. With it and in such password recovery environment, you will don't need to worry about data lost or damaged.
This is a video showing how to use it.
http://www.youtube.com/watch?v=quxuEqpG6f4&feature=youtu.be
Jul 11, 2008 | Computers & Internet
forgot password for vista login
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Jul 08, 2008 | HP Pavilion dv6000z Notebook
282 people viewed this tip
David Payne
David Payne
