Tip & How-To about Sony RDR-HXD860 DVD Recorder/HDD Recorder
Tips on how to fix the DVD player ( not eject )
You have to check the try loading belt of you DVD. if the belt is loose or broken the will not be ejected. you can see only OPEN in the display. You can simply check is it related to belt. Power on the DVD player and then press the eject button. Place you ear on the top of the player and listen is there is any humming sound (sound of motor running). If you hear the sound then the belt have some problem.if there is no sound then the problem is related to the electronic part which drives the motor. if so you have to change the motherboard of you DVD player. Because the all the parts in it are S.M.D( surface *****device) also the availability of the part is very rare.
If you here the sound then you Can rectify the problem by replacing the belt.Normally you cant see the belt from the top of the mechanism. Because it is beneath the tray. you can see it only if the tray is in eject position.
Remove the top cover of your DVD player. As it is DVD player you can eject the tray manually. for that watch the bottom of your DVD player. You can see a slot closed by a plastic strip just bottom of the mechanism. Pull out the plastic strip. Watch through the slot. you can see a Noach which you can move manually to the left and right. put a screwdriver in it and pull the Noach to the side. the try will get ejected. Not fully but partially. You have to pullout the tray fully manually.
If you closely look at the inner end side of the try then you can see a motor and belt. if the belt is loose it will be in there in the motor pulley and in the wheel. if its broken broken then you have to find it where it . Take the belt as sample and bring a new one. you will get the belt at any of the electronic spare parts shop near you. Put the new belt in the position. insert the tray by pushing it in to inside slowly. power on the DVD player and the press the eject button.
Sony RDR-HXD860 DVD Recorder/HDD Recorder Logo
Polaroid 2001G DVD player and recorder won't eject or go past the HELLO. POWER ON
If the set switches ON, and the display says 'eject' when you press the eject button, and the disc tray do not eject, the fault should be with its mechanical side. Check and replace the disc loading mechanism. Prior to that, check whether the loading belt is broken or not. If broken, replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 12, 2014 | Televison & Video
sony slv-350p dvd combo disc tray wont open
Might be to a broken loading belt, or damaged loading gear wheels. Check it. If gear wheel is faulty, it will be best to repalce the disc loading mechanism.
May 14, 2012 | Sony SLV-D350P DVD Player/VCR
RCA L32WD26D TV/DVD/HD Combo - dvd wont eject
Hello
Check the loading motor and loading belt. If loading motor has damaged, or loding belt has broken or loose. the in-out tray mechanism won't work well.
Mar 03, 2012 | RCA L32WD26D HDTV/DVD Combo
dvd draw will not open yamaha dvr s60
Hello
either its loading motor is faulty, or the loading belt is broken. The commands are reciving, but it does not work mechanically. A mechanical fault indeed.
Feb 28, 2012 | Yamaha DVR-S120 DVD Player
tray not ejecting
check the door belt wich is placed underneth of the driv mechanism.if the belt is not broken or getting loose in size then check the motor pully then motor. best wishes do with care.
Jun 14, 2007 | Akai DVDS3500 DVD Player
3,518 people viewed this tip
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
