Tip & How-To about Plumbing
Freeing Faucets / Taps
When reassembling faucets (taps) after replacing washers, smear Vaseline petroleum jelly on the threads. This prevents the faucet from seizing up and will make it easy to unscrew the top of the faucet in future
Plumbing Logo
Am installing a new American Standard faucet. Does it need to be lubed prior to installation?
I think American Standard probably is correct, especially if there is a history of swivel faucets seizing over time.
Dec 11, 2013 | American Standard 4205.104.075 Reliant...
We are getting a constant drip through the faucet when both taps are turned off. please advise solution
Hi mark stopfor...
Sounds like the sealing washers are in need of replacement.
Look under the sink and find the shut off valves to the faucet.
Shut off water, remove handles from faucet, then use a wrench to remove the insert that holds the sealing washers. Replace the washers with new ones that you will have to purchase and reassemble...that should solve your leaking faucets...
Free Answer...Please take time to rate me.
Jun 13, 2011 | Home
dripping faucet
first step would be to change the rubber washer or o ring.
  1. buy a proprietary washer kit from any DIY store.
  2. Turn water off at isolating valve on teh pipe underneath the sink / bath or at the mains and or hot water tank as appropriate
  3. Remove the top of the faucet (often there is a plastic circle at the top that prises off to reveal a screw - mixer taps may have a grub screw on the side)
  4. Gently using a wrench to loosen the nut unscrew and remove the tap (faucet) barrell (middle bit)
  5. Remove nut that holds washer in place and remove it or, in the case of an O ring - prise it off with a pin or needle.
  6. Reassemble in reverse order - do not over-tighten.
If that doesn't stop the drip then the seat that the rubber washer / O ring seals against may be pitted or grooved. Either buy or hire a 'tap (faucet) seating tool.
  1. Turn off water before opening the faucet
  2. dismantle faucet as above
  3. Find which of the sleeve adapters that comes with the seating tool is teh right one to screw into the top of the faucet body
  4. select the grinding disc that is closest to the size of the seat and screw it onto the end of the seating tool
  5. Screw the tool into place in the top of the faucet body - just finger tight.
  6. Pressing down firmly with even pressure (but not too hard) on the top of the seating tool rotate the handle backwards and three or four complete rotations.
  7. reassemble the faucet but DO NOT close the faucet off
  8. slowly turn the water back on and allow it to flow hard for a few seconds to flush and debris out of the spout
  9. Slowly close the faucet and check for leaks.
  10. If necessary repeat re-seating process
Feb 27, 2011 | Home
i have mixer taps on my bath, cold water tap works
Remove the tap outer cover. Take out the barrel & inside there is the washer on the end of a screw which slides in and out when the tap is turned. This could have been turned too far out and will not go back in. Clean both the screw thread and inside the barrel, lubricate with petroleum jelly or similar and reassemble & test before replacing the barrel. Again lubricate all threads.
Alternatively buy a new barrel
Mar 11, 2010 | Home
358 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
