Tip & How-To about Cooper Industries Weller Field Soldering Iron, Controlled Output
Step by step procedures for soldering.
Most repair procedures on modern TVs require some kind of soldering. It is not a process which you can learn without spending some time getting the proper equipment and practicing until you can make a good solder joint in your sleep.
First you need to understand that recently, within the last 5 years, the type of solder has been changed. Originally solder contained lead which can be dangerous, although I would wager that no one licks circuit boards! In order to make solder environmentally friendly more antimony has been added. This means that solder melts at a higher tempreture and does not adhere near as well. Flow is also compromised. Most solder joints now look like what we called cold solder joints in the past.
To be able to solder correctly you will need a good iron or better yet a soldering station. You will also need to purchase some lead based solder and some solder with no lead. This is because you do not know at this point what circuit you will be working on.
There are many vendors out there selling soldering equipment. http://www.mcminc.com http://www.encompass.com http://www.digikey.com just to mention a few.
The most versatile station would be a unit with an adjustable tempreture range. Then you can solder with lead based or non-lead solder. Lead based solder flows at about 750 degrees farenheith. The newer non-lead based solder flows at about 950 degrees farenheith. This means that you have to be extremely careful not to overheat components.
If you cannot afford a variable tempreture unit you should probably purchase several pencil gun units. I would recommend getting a 25 watt, 35 watt and a 50 watt unit. Also get a good solder ****** and some solder wick. Do not get the cheap wick as it does not work after it corrodes due to the oxygen in the air. You will need the solder wick to remove any bad parts.
When you are ready to solder let the iron or station heat up to the correct operating tempreture. Trying to solder too soon will give bad results. When the unit is hot and ready to go, place the tip (which should be conical) on the part to be soldered. Do not hurry it. Let it melt the solder and wait to see it flow before adding solder wick or removing the part.
Reverse the procedure when soldering in a part. Do not have the iron in contact with the part any more than necessary as you may overheat the unti and damage it.
If you follow these instructions you should be able to solder any board, part or device which needs it.
Thanks for using FixYa and for the great rating.
hardrocko
Cooper Industries Weller Field Soldering Iron, Controlled Output Logo
just had 03 l200 bcm repaired at aes how do i get it to work now
Any PCM, BCM, or ignition switch assembly that's replaced requires what's described as a Passlock re-learn procedure to synchronize the three subassemblies for proper operation. This either takes place at Saturn or during a 30-minute DIY procedure in three 10-minute cycles. The procedure is basically to leave the ignition ON for 10-minutes, cycling the ignition OFF and then ON for another 10-minutes and once more until repeated three times, never starting at any time. After the third cycle the ignition can be turned to start the engine to confirm that all components have successfully been synchronized. A failure to start means an incorrect re-learn procedure was done and needs to be repeated all over again. The security light will flash during the process and eventually turn off altogether as indication of successful re-learing security codes for any new part replaced. What isn't changed are the VIN and mileage that Saturn equipment can do. The security system is divided into three parts; the ignition switch sensors, the PCM, and the BCM. Any one of these subassemblies being replaced requires the BCM to relearn the new replacement part otherwise you'll just have a dead engine unable to run. New BCM's come as blanks that Saturn address' with their Techtool II with VIN and mileage copied from the failed BCM. 'Field' BCM's removed from vehicles still retain VIN and mileage that can only be changed by Saturn. There may be other programmed accessories that have to considered to be compatible to the original one removed for replacement.
key remotes
Replacing the BCM will require the remotes to be reprogammed. The problem is that you need a scan tool with the proper software to perform the programming. Here is the procedure for reprogramming if you have access to a tool. If not you should put a call into a local garage that does diagnostic work or the dealer. If it were just a battery change you could resync without programming.
Jul 14, 2012 | 2003 Saturn L-Series
over heating
  1. Auto inspections of the vehicle may produce results contributing towards restoration. For example, the auto technician makes the evaluation as separate arrangement from which problematic areas are ascertainable. The result findings are documented as diagnostic draft plans from which repair authorizations are achievable. At which point, diagnostic without repair requirements would least requires any further procedures. However, once the vehicles diagnostics produce result requiring expert vehicle repairs, the next sequence of procedures are initiated. First, vehicle repairs require constituent components either permanent parts or depleteable resources constituents prior to workshop initiation plans. Auto technician diagnostic plans would usually contain the damage of the vehicle. A decision to commence restoration of the faults would produce estimate drafts in parts repaired for either replacement acquirable, leasable or alternately. The next sequence includes calculations estimates in resources that would be required contributing towards entire workshop restoration process procedures.
Jan 22, 2011 | 1991 Mitsubishi Eclipse
1997 Saturn SL Series......My gearshift "broke
Jan 22, 2011 | 1997 Saturn SL
i was playing Modern Warfare 2 and my system turned off and the red light blinnked i predded the button once and it stopped blinking i pressed it again and it flashed yellow then went sollid red again
PS3 turns off when playing games and remain blinking red light : You need to repair your console. Learn the step-by-step way to fix your PS3 components is best way for you. I suggest a secret repair kit for you to fix the PS3 errors. This is an all-in-one style guide that help you to fix many cases of PS3 problems. The author is really kind and helpful to his customers. Learn the D.I.Y. way to fix PS3 issues can save you much money. You will receive much more than you spend on it. Because you can help your friends to fix their PS3 too! Please consider to buy it and share what you have learned !
PS3 Red Light and Yellow Light Fixing Guide : http://bit.ly/fixya-ps3
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
1,537 people viewed this tip
Top Cooper Welding Tools Experts
Bill Boyd
Are you a Cooper Welding Tool Expert? Answer questions, earn points and help others
