Tip & How-To about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
How to chanmge codes on most digital safes
To change the code on most digital safes.
you need to access the red button usually found inside the safe by the battery area.
Press the red button until you see two flashes. then enter your new code.
PLEASE try the code BEFORE you close safe!!
Thanks
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
how do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
Where do i get instructions for changing the code on my hardline digital safe. The instruction paper that came with it appears to be for another safe. the paper mentions a red button where no red button is present. is there perhaps a product code or serial number somewhere on the safe where I might have over-looked?
I had this exact same problem. Then I realized the red reset button was actually INSIDE the safe itself. So you need to enter the factory default code "159" to open the safe, then on the inside of the safe next to where the batteries are is a red button. If you press that, the yellow light will flash and you'll get two beeps. That means you can now enter your own combination. I hope this helps.
-Mike
Jul 06, 2010 | Safe International Digital Electronic Safe...
i have a safewell electronic safe and no keys and lost code ex2007127402 can i have a code to over ride and open it
hi : about the stockwell safe ex200----- 2535-EA
if the safe still has charged batteries you can deactivate any sceurity code by access through a small hole on the rear of the safe, if you can get to the rear area of the safe.. You need a long screwdriver to reach to the inside of the front of the door . Their is a reset button on the inside of the door in the lower right corner area( "B" button) on the end - not on the flat face surface of the door but on the vertical face( hing plate). You'll have to feel around and push the screwdriver sideways to push the button in.it will beep . YAHOO- YUH DID IT !!!. Then you can reset your own code.if you need further instructions call me . icq. 33819110 or echarron1@cogeco.ca
Jul 26, 2009 | Locks & Locksmithing
bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
Dec 19, 2008 | Check Point Network Adapter
sandleford electronic safe es20
have just had the same problems if you had the key there is a red button inside the door to reset the code but obviously no key no red button I have the sandleford number to call 03 97750699 or try the factory pre set 159 A or B see how you go
Aug 20, 2008 | Computers & Internet
1,134 people viewed this tip
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
