Tip & How-To about Computers & Internet
Wireless Network issues. Validating identity and Certificate Errors in Windows XP and Vista
At times after you have entered the correct password for the wireless network on your computer you are unable to connect to the wireless network and see the below mentioned errors:
  • "Windows was unable to find a certificate to log you on to the network."
  • "Validating identity" replacing the name of the wireless network.
  • A pop-up window requesting for login credentials off the wireless connection.
To avoid these error messages, you need to manually create or add a wireless network profile. Follow these steps to manually add a wireless network on Windows XP and Vista computers.
Manually add a wireless network on a Windows Vista computer:
  1. Click Start, and then select Network.
  2. Select Network and Sharing Center.
  3. Click Manage wireless networks.
  4. Click Add and select Manually create a network profile.
  5. Type the SSID, select the type of security and type the wireless password in the Security Key/Passphrase field.
  6. Select the Start this connection Automatically and Connect even if the network is not broadcasting check boxes.
  7. Click Next and close the window.
  8. Go to the Network and Sharing Center and select Manage network connections.
  9. Right click on Wireless network connection and then select Status.
  10. Click details and check the IPv4 address.
  11. If there is a valid IPv4 address, check if the computer can access the Internet wireless.
Manually add a wireless network on a Windows XP computer
Note: The following steps are for a wireless network that has WEP security.
  1. Click Start, then select Control Panel.
  2. In the left pane, select Switch to Classic view.
  3. Click Network Connections.
  4. Right click Wireless Network Connections and select Properties.
  5. Click on the Wireless Networks tab.
  6. Click the Add button.
  7. Enter the name of the wireless network (SSID).
  8. Set the encryption type to WEP.
  9. Clear the key is provided for me automatically check box.
  10. Enter the network key and confirm it. Note: Make sure that "This is a computer-to-computer (ad-hoc) network" is not selected. Click OK, and then click OK again.
  11. Right-click Wireless Network Connections and select Status.
  12. Click on the Support tab and check if there is a valid IP address.
  13. Check if the computer can access the Internet wirelessly.
If you still receive the same error message after manually adding a wireless network on a Windows XP computer, ensure that IEEE 802.1x authentication of the wireless adapter is disabled.
To disable IEEE 802.1x authentication:
  1. Click Start, then select Run.
  2. In the Run dialog box type ncpa.cpl and then click OK.
  3. Right-click the Wireless network connections icon, and then select Properties.
  4. Click the Wireless network tab.
  5. Click the Properties button beside Remove.
  6. Click the Authentication tab, and clear the Enable IEEE 802.1x authentication for this network check box.
  7. Click OK to update the settings.
This TIP applies to:
All Windows XP and Vista computers that display the listed error messages when attempting to connect to wireless network of routers (specifically NETGEAR).
Computers & Internet Logo
Why can't I connect to home WIFI?
Firstly, I would reset the router by removing the power for 5 minutes and then try again.
Jan 21, 2017 | Samsung Computers & Internet
did not connect to internet
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (SSID, WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access). Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 31, 2013 | D-Link DIR-605 Wireless Broadband Router -...
the setup wizard does not show the connect button after following the steps. So we cannot connect to the internet using the dlink dir-412 router.
For each PC that needs to connect to the DIR-412 wirelessly, you must ensure that the correct Wireless Network Name (SSID) and encryption key has been entered.
Windows 7 On your computer, go to Control panel --> Network and Sharing Center and Click on "Connect to a Network then select on the Wireless Network Name (SSID) and enter the password/encrytion key.
Windows XP On your computer, go to Control panel --> Network Connection then under the network task pane select View available wireless networks then then select on the Wireless Network Name (SSID) and enter the password/encrytion key.
Jul 25, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
Kindle 3rd Generation -- Linksys WRT54G2 router. Kindle won't recognize password set in router -- Always says "Unable to connect to Wi-Fi Network. Would you like to enter the passworsd again or manually set up this network?" Any ideas?
First Check if u are Entering correct Password
Plz also Check security TYPE u have Chosen for Wireless
Might not work with Advanced Security
Try WEP or WEP
All the Best.........
Oct 07, 2010 | Linksys Wireless-G WRT54G Router
connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Jun 25, 2009 | NetGear DG834G Router
776 people viewed this tip
David Payne
David Payne
