Tip & How-To about Washing Machines
Washer not spining Top Loader Part II
In this tip I will discuss tips towards checking the motor ,transimssion, and timer on Top load model washing machines. Please also see part 1 of washer not spining Top loader for more tips as well.
Washing Machines Logo
The timer ticks but the washer only fills with water and doesn't drain or move.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 06, 2011 | GE WBSR3140DW Top Load Washer
Will spin empty but with a load will not spin.
heatman101
Nov 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have an electrolux washing machine model atfb6700 front loading bought in 2008 that does not spin. It will turn on the wash cycle but the motor buzzes in both cycles. Is it the motor or motor boards?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is toasted...
heatman101
Sep 09, 2010 | Electrolux Washing Machines
ficher and pykel top loader smart drive 9 model mw059nz - won't spin or drain but have emptied by hand tilted back and check for all blockages, coild it be the spin motor?
heatman101
Sep 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
magtag washer wont spin or drain, model #lat9806aae
heatman101
Sep 02, 2010 | Maytag Washing Machines
390 people viewed this tip
Top Washing Machines Experts
