Tip & How-To about Cell Phones
To make your number to appear as private
1 There are many ways to enable call blocking. If you have an old phone, skip to step 52 First, look around for a option under your phone's call settings menu called "Show/Hide My Number3 When you select it, it will most likely be set to "network default," which means that displaying Caller ID information would be dependent on your carrier's network setup for your mobile number. Change it to "hide number" to have the phone ignore the network setting and stop reporting your caller ID information.4 Check if it works by making a test call. You may also need to turn your phone off and back on for the change to become effective5 If it does not work or the option is not available, begin your call with *67, if you're in North America. So, for example instead of dialing 1-718-555-0123 you would dial *6717185550123. If in the United Kingdom and Ireland, then dial 141. If in Australia then dial 1831 before the number, for example.are helpful or not ?
Cell Phones Logo
I want to know how to enable Third Party Cookies on Windows 10 please.
For enabling third party cookies follow this steps:
1. Open Internet Explorer by clicking the Start button ,
2.Click the Tools button, and then click Internet Options.
3.Click the Privacy tab, and then, under Settings,
4.Click Advanced ,Then you'll get Advanced privacy Settings window. There you can see the Third-Party cookies options.
5.For enabling Third-Party cookies, Click the Accept option. That's it.
Oct 22, 2015 | Google Chrome
I want to block unwanted callers from calling me . i am unable to block these callers
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
Apr 11, 2011 | Samsung Star GT-S5233 Cell Phone
I transferred all the phone numbers from my old sony ericsson cell phone to my sim card, but cannot figure out how to copy all the sim numbers onto my new sony ericsson vivas pro.
To transfer your contacts through the SIM card:
  1. Copy your contacts from your old phone to your SIM card. If you need help with this, please consult the old phone user guide.
  2. When the copying is done, move the SIM card to your new phone.
  3. Select Menu > Contacts.
  4. If the phone asks you to copy info from the SIM card, skip steps 5-10.
  5. Otherwise, tap Options > Settings > Contacts to display.
  6. Select SIM memory > OK, then tap Back.
  7. Tap Options > Mark/Unmark > Mark all.
  8. Tap Options > Copy > Phone memory.
  9. Tap Options > Settings > Contacts to display.
  10. Select Phone memory > OK, then tap Back.
Feb 28, 2011 | Sony Ericsson Vivaz Cell Phone
MP3 enabling
Step by step to enable mp3: Two part process. To enable outside phone buttons to play mp3: From main screen press OK and then the number 0 seven times (you?ll see a series of question marks disappear). Then scroll all the way down and press #11 (Music Setting). Finally, choose My mp3. To get MP3s to play, including ringtones ? Press OK (Menu) and go to Settings and Tools, press 5 (phone settings), press 2 (shortcut key), press 5 (play key), and choose my mp3s.
Jun 21, 2007 | LG VX8300 Cellular Phone
208 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
