Tip & How-To about Washing Machines
Washer not spining Top loader part I
There are a couple of key parts in makeing the tub of the washing machine spin and here are some of the ways you can test whats wrong with your washer and why it is not spining. The most popular for all direct drive units is of course the drive couple which is the small plastic and rubber piece that attaches the motor to the transmission these tend to break more often then any other piece due to when made for manufacturers they do not have any metal on the three pronged connector nor in the center the replacement coupler does come with a metal washer in the center which prevents the actual spining stress caused on the piece to break the small arms that come off the connector. the best way to test for the coupler is by visual inspection so remove the cabinet, pump and motor and assure that the drive couple has not broken at all. if you need a video of how to replace the drive coupler click here http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5501893181&kw=whirlpool%20coupler&gclid=CMSzgdOGvqgCFUSo4Aod1SgCqA
Another problematic area would be the clutch that is connected to the transmission. One of the easiest ways to check the clutch is to set the unit to spin with no clothes on the inside. While the unit is spining use the palm of your hand and press your palm against the inside wall of the inner tub if the tub slows or stops this would mean that the clutch is worn or defective and would need to be replaced. Here is also a video of how to replace the clutch click here http://www.youtube.com/user/RepairClinic?v=tVc6SZ2DD4U&feature=pyv&ad=5454782141&kw=washer%20clutch&gclid=CKut8bSGvqgCFYFM4Aod4n2trQ
there are also other parts that cause the unit to spin such as the motor, transmission, and timer and these will be discussed in part 2 So look for Washer not spining Top loader part II Thanks again for using Fixya
Washing Machines Logo
washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
Jul 20, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana - noise while washing, not when spinning
There is a device called an Oldham coupling that connects the output of the electric motor to the transmission on the tub. It uses rubber vibration dampers in the coupling. Get some WD 40 and spray it generously on the coupling. You will have to tilt the machine nearly onto its side to see and spray the coupling so get some help.
Jun 22, 2009 | Amana DLW330RA Top Load Washer
agitator won't turn and tub won't spin
The motor coupling is broken, the part located between the motor and the transmission.
Dec 25, 2008 | Whirlpool Washing Machines
kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer makes noise at start of the Spin Cycle
its your basket drive or sometimes called brake spin tube also comes with new clutch, ,transmissions wouldn't make that noise in only beginning of spin. your on your way to being a repair tech good job
Nov 10, 2008 | Kenmore 22422 Top Load Washer
839 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
