Tip & How-To about Televison & Video
Resetting a Samsung TV to the factory defaults.
Method 1: Hold Exit Button until a reset menu comes up, select ok.
Method 2 (Via the service menu):
  1. Turn the TV into Standby (off)
  2. Press these keys one after another - (info) (menu) (mute) (power)
  3. The TV is back on and you are in the Service MENU.
  4. Now press your down arrow key until you get to number 12 on the on screen options, it's marked RESET.Push the arrow key to the right, this will switch off your TV and reset it back to when you first got it.
Televison & Video Logo
sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
can the service menu for the LG 52sz8d dlp tv be accessed from the orig remote not the service remote just installed new lamp and tv was working fine for 1 week now the lamp indicator light comes on and flashes red then shuts off
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Hope this helps. Regards, James.
Apr 22, 2010 | LG 52SX4D 52" HDTV
1,232 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
